Does anyone have any experience with Visaton louspeakers and kits? www.vistaton.com
#2 |
What kit or design are you interested in? I'm using a slightly modified Vox 200 and can't fault it. They're a little on the expensive side but well worth the dollars.
Cheers
It's true there is a fool born every minute; it's also true they don't die that fast. |
#3 |
I kind of on a low budget and I'm interested in a MTM speaker design for my tube amplifier. I want a loudspeaker with sensitivity above 90 db...
I was wondering how the Visaton speakers are compared to other speakers like ex. vifa and perless. |
#4 |
Yes, I think the visaton drivers are a little on the expensive side if you're on a limited budget. Why don't you take a look at Wayne's Dayton 3 MTM design which is around the 90 db sensitivity range. I would be an easy build and less expensive than the Visaton drivers.
Cheers
#5 |
Sorry, forgot to post the link for the Dayton 3.........here it is http://www.speakerbuilder.net/web_fi...D3/dayton3.htm
#6 |
Thanks! But the Dayton speakers are very exprensive shipping to norway from Parts-express.
#7 |
http://www.troelsgravesen.dk/C17.htm
I think its a fairly cheap project with high quality - take a look at other HES projects - its right in your backyard and I am sure its much better that any visaton kit |
| Visaton B200 dipole experience? | tubesguy | Full Range | 26 | 23rd May 2012 12:25 AM |
| corner loaded louspeakers | Sjef | Multi-Way | 8 | 7th April 2009 08:14 PM |
| "Visaton - is it worth?" or... "Share your Visaton experience" | mr_push_pull | Multi-Way | 10 | 7th August 2004 06:18 PM |
| Visaton drivers .... any experience? | alvaius | Multi-Way | 2 | 25th September 2002 07:16 PM |
| Page generated in 0.08901 seconds (72.10% PHP - 27.90% MySQL) with 10 queries |
