I have found this design and realy quite fancy having a go. Size wise they are acceptable, although I would like to extend the cabinet down to make them into a floorstander (void to sand fill or house X-Overs) and would make a curved front baffle and make the horn out off wood, similar in style to these but without the seperate horn unit.
B&C drivers seem very well regarded and are easily available in this country for affordable money (about £400 for the 4 units) and the looks have wife approval! Anyone have any comments? Cabinet plans and X-Over Bass driver HF unit Paul. |
#2 |
For what would you use these exactly?
Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer. |
#3 |
Neat. B&C's own recipe is probably pretty good.
Earl Geddes, who is really a speaker guru, ( http://www.gedlee.com/ ) uses B&C drivers. I suspect he would advise you to radius the edges and the corners of the cabinet and also around the bass driver and horn to minimize refraction. He likes big radii - at least 2" - given you want to curve the front of the cabinet anyway, aren't you looking at a baffle that would accomodate some radiusing? His thinking, as expressed before he stopped writing to online discussion groups, is that minimizing refraction would give less psycho-acoustically bothersome distortion at high listening levels. I tried it with the top part of my Klipsch horn klones and it did make a nice difference. And, heaven knows, you certainly will be able to produce big dBs. What kind of waveguide/horn did you have in mind? The HF unit you have in mind is a really modern unit and waveguide design really has moved on since Voice of the Theatre, great speaker though it is. |
#4 | ||
As for the horn, B&C make one that they use for this design, here . If B&C cant/wont let me have the dimentions then I will just buy one and copy the shape to wood. Paul. |
#5 | |
Paul, sorry I didn't answer sooner
#6 |
Are you using a subwoofer or EQ? As these aren't going to do much below 50-60 Hz. The 12" will become more and more directional between ~1 kHz and crossoverpoint with 1".
Personally I would rather use a (8")10"/1" or 12"/6"/1" at home. Am using 12"/1" only for HT (but your choice is definatly a step up on the quality ladder). If directionalty isn't a problem you could consider a coaxial. B&C does have a nice 8"/1" IIRC. Wkr Johan
#7 |
Guys, thanks for the feedback, much appreciated
I wont be using any eq. or a sub so the speaker will have to do its own work in the bass. They are going to be used quite close to a rear wall (not at particularly high volumes) so I was hoping that the in room response would be acceptable. I have had a play with WINisd with regard to tuning but with little success.....perhaps this driver would be a little better.....it seems so from the plot although its not a huge differance. I have also come across this Fane design that has a lower (quoted) bass responce so I am confident I can get the results I want from a 12"/horn tweeter design. There is of course the BMS compresion mid/tweeter that go's down well into the midrange but I have no idea how much these things cost. Paul. |
#8 |
Hi Paul,
I think you're best off sticking with the 12PLB76; it will match nicely with the HF driver/horn both with respect to the crossover and dispersion. If after you play them for a while and think you want more bass, then stash a little subwoofer somewhere out of sight. |
#9 |
Cheers Frank, I'll build it as per the B&C plans and take it from there
Paul. |
#10 |
Not bad. I'd use a different horn and HF driver myself though.
| looking for opinions on amp design. | armstrom | Solid State | 1 | 27th June 2008 08:11 PM |
| Opinions on this HT-sub design please. | ßart West-VL. | Subwoofers | 19 | 7th May 2008 02:05 PM |
| like some opinions on this design | scottericsonon | Multi-Way | 9 | 3rd July 2007 09:56 PM |
| ht design opinions | ucla88 | Multi-Way | 12 | 4th January 2002 04:58 AM |
| Page generated in 0.11539 seconds (81.17% PHP - 18.83% MySQL) with 11 queries |
