Old 21st November 2006, 01:00 PM   #1
Default Cheap 2-way speaker
Anoyone know of a cheap well tested DIY 2-way floorstanding speaker with 8 inch woofer?
Old 21st November 2006, 02:03 PM   #2
sdclc126's Avatar
How cheap? Here is one possibility, but it has a relatively complex crossover:
http://www.partsexpress.com/projects...crossover.html
Soft Dome
Old 21st November 2006, 03:50 PM   #3
Thanks!
How is the quality on the DAYTON drivers?
Old 21st November 2006, 04:22 PM   #4
sdclc126's Avatar
For the price the Daytons are rated very highly, so if you're going budget this is probably a great way to go. These speakers, according to the designer, give very good bass due to the 8" woofer, the fact that the Classic series has good low frequency extension, and the cabinet is large and ported.
There are not a lot of 8" 2-way designs out there that I know of, and this one seems to strike a nice balance with price vs. performance vs. compromises.
If you are capable of building your own cabinets and the crossovers, take a stab at this one - remember once you've built it you're not "locked in" - you can always experiment with different drivers, crossovers, box alignments, etc.
Soft Dome
Old 21st November 2006, 05:21 PM   #5
leadbelly's Avatar
IMHO, Dayton/Parts Express is a very bad choice for you, high international shipping cost completely negates the good value for Dayton drivers. Look to http://www.audiocomponents.nl or http://www.humblehomemadehifi.com first.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 21st November 2006, 05:39 PM   #6
sdclc126's Avatar
Yes that's a good point. The Vifa drivers might be the choice in that case. He's looking for an 8" 2-way - can you suggest a derivative from that site?
Soft Dome
Old 21st November 2006, 06:04 PM   #7
The so-called "designer" knows next to nothing about crossover design.
(Or the bracing required in large cabinets for that matter)
Here is someone who does know what he is talking about crossover wise :
http://murphyblaster.com/content.php...ifa_Tower.html
The bracing scheme is shown is poor. Will suggest one if you build it.
/sreten.
Old 21st November 2006, 06:47 PM   #8
sdclc126's Avatar
Autheim - perhaps at this point it would be helpful if you let us know what your budget is? Is $220 in the ballpark?
Sreten - I had a sneaky suspicion that the crossovers on the Noah 8s were needlessly complex - there's got to be a simpler solution with a paper woofer (even 8") and a soft dome tweeter!
Soft Dome
Old 21st November 2006, 06:55 PM   #9
Around $300
Planning to run them on a tube amplifier (2x40w) so sensitivity above 90db is probably best...
The Opal seems like a nice diy project...
Old 21st November 2006, 07:10 PM   #10
The M21WO-39-08 in the opal is a discontinued vifa speaker...
Which Cheap Speaker For My Amp? louisdavies Full Range 7 29th June 2009 05:17 AM
cheap speaker parts chchatham Multi-Way 8 5th March 2005 01:49 PM
Cheap PC speaker system... 454Casull Full Range 11 22nd February 2004 03:18 AM
cheap speaker improvements jeffm Multi-Way 15 24th November 2002 08:20 AM
Page generated in 0.16229 seconds (57.40% PHP - 42.60% MySQL) with 10 queries
