Hi everyone. I need some advice. If I were to build a 3way MTMWW or MTMW what would be the tradeoffs of using 6.5" or 5.25" as the mid?
This speaker will be used for 2ch music and HT, sometimes at higher volumes, thus the multiple drivers. I've been reading some of Dr. Floyd O'tool's (sp?) findings concerning power response and it's effect on SQ, and some of the drawbacks concerning the MTM layout and it's off axis lobing around the wavelength between the mids' acoustic centers. Smooth power response and minimal cancellation between mids will be a design goal with these. Given that, I decided to use 5.25" for better HF off axis dispersion and the ability to have closer acoustical centers, minimizing off axis lobing. So what am I losing by going this route? Low distortion even at higher volumes is important to me. Obviously the 6.5" would keep distortion lower at any given SPL. I assume power compression would be lessened at any given SPL with the larger woofer. So what else should I consider? |
#2 |
MTM 3 ways don't make any sense to me at all. 2 ways do, but for 3 ways why have two mid drivers ? |
#3 |
Sreten...could you clarify that? It looks like he may be using a woofer for the low end, making it a three way. If one were to use a larger driver for say...under 100Hz, then why not do an MTM with an additional woofer? Efficiency might be an issue depending on the drivers, but couldn't that be offset by multi-amping...or attenuating the mids (if you had to)?
Regards, Aaron |
#4 | |
MTM(+nxW) versus TM(+nxW), two mids does not make sense to me. One high quality midrange is the way to go. |
#5 |
I understand that it does not float your boat: why? Is it cost? the MTM lobe pattern? Efficiency mismatches? Aesthetics?
Why not build MTMW where the W was below 100Hz or so? The MTM may be used because the designer/listener wanted the response of an MTM with some low end support but did not want multiple enclosures? You have helped me before with technical help, but this seems to be more of an opinion than a technical arguement. I am curious from a technical standpoint.
Regards, Aaron |
#6 |
MTM + (W below 100Hz) is technically a 2-way MTM + sub. |
#7 |
It's a semantics problem? I've been asking the technical basis of your opinion because I like the idea of the original post. All you've provided is further opinion based on your working definition.
If I were to talk about an MT setup with separate subs...that would be a 2-way plus subs. It's still a 2-way if I make the MT and integrate stereo subs into the same unit as the MT? Am I wrong when I say "3-way" to indicate that all three driver types are in the same unit? What is the definition of a 2-way? a 3-way? Would the W have to come in at 250Hz to be a 3-way? In the end, why don't we just call everything 1-ways, plus T and/or plus W? Don't "full range" 3-ways go below 100Hz?
Regards, Aaron |
#8 |
frugal-phile(tm)
An MTM -- unless using quite small drivers) forces the XO to the tweeter to be lower than i find optimal....
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
How small is "quite small"?
I have seen other debates about MTM's, so I will not delve too deeply.
Regards, Aaron |
#10 | |
For music listening I really like the MTM with a first order series, so regardless of theoretical issues you can cross higher than normal dictates. Others have heard this style of speaker, read reply #16 on this link. http://www.audiocircle.com/circles/i...topic=29980.10 |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Charcoal "Supreem" hi-density foam "enclosure" | IG81 | Multi-Way | 0 | 23rd April 2009 01:34 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.10620 seconds (79.55% PHP - 20.45% MySQL) with 10 queries |
