Old 20th November 2006, 01:29 AM   #1
Send a message via AIM to legendaryfrog
Default what cables do you use in your speakers?
what cables do you use inside your speakers?
i, personally use old monster cables left from 3 years ago, when i bought my first "real' HT.
Old 20th November 2006, 01:50 AM   #2
Default Do cables matter??
Are you a newbie, or maybe just interested in starting an atomic war?
The following thread should give you an idea of the passion surrounding the question you just asked.
I don't believe cables make a difference, any input?
Hope you have some fun.
Best,
Ralph
Probably a silly question, but ........
Old 20th November 2006, 01:54 AM   #3
suzyj is offline suzyj  Australia-Aboriginal
suzyj's Avatar
I use 14 AWG PVC insulated hook-up wire. It's the same stuff I used for wiring up my amp. 8 mOhm/metre resistance, with 105 degree insulation.
1 metre of 14 AWG wire has about 0.009dB loss in series with an 8 Ohm driver.
Suzy
Old 20th November 2006, 01:58 AM   #4
TerryO is offline TerryO  United States
TerryO's Avatar
Let's see..............
Triple braided Cat-5, 16 AWG Radio Shack speaker wire, 16 AWG Carol Wire Twisted (1 or 2 pairs), 14 AWG (solid) Romex Residential Wire, etc.,
It all works and I have no particular favorite if the price is equal. Just to let you know, I've never heard any difference between wire but I'm older than dirt, so my hearing isn't so hot. Besides, and perhaps more to the point, I think that anything that gets the voltage and current from point A to point B is going to sound an awful lot alike. Your Speaker's crossover inductors and/or voice coil will have a greater effect on the sound than a few inches of internal wire, at least in my experience.
YMMV,
Terry
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 20th November 2006, 02:41 AM   #5
Cloth Ears's Avatar
legendaryfrog,
You should be using the search facilities on this forum, rather than trying to start another cable thread. There's heaps of information out there, with 3 schools of thought:
1) cables make no difference
2) cables make heaps of difference
But a lot of the threads (which do have useful information in them) end up being slanging matches between one or other of the cable factions.
Incidentally 12-16awg cable, depending on mood. Mostly the same stuff that I use as speaker cable.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 20th November 2006, 03:11 AM   #6
im not asking which cable is better or anything like that. i dont beleive in audiophile cables. this is mearly a simple question.
Old 20th November 2006, 03:13 AM   #7
I don't use cable, I use ratshack 18# wire.
Incidentally - ever anyone looked inside the highly valued kef 104/2? I doubt it is more than #20 for the tweeter and midrange.
Old 20th November 2006, 03:16 AM   #8
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Wire...
14 Gauge brown polarized "Zip cord/lamp cord"......good for runs up to about 25 ft...longer I'd up the size.
_____________________________________Rick.........
Old 20th November 2006, 03:34 AM   #9
TerryO's Avatar
You make a good point, and there are lots of highly regarded speakers using "inferior non-audiophile grade" componets. Hell, I've used them myself, without much reget.
I have had good luck by eliminating the speaker terminals entirely, straight wire from crossover to the Amp's terminals (even better would be hardwired end to end!). The best connector or terminal can never be any better than an unbroken wire.........but it CAN be worse.
Best Regards,
TerryO
ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! ssabripo Everything Else 3 26th October 2006 02:33 PM
DIY speakers cables with several non-insulated cores pk Multi-Way 5 15th April 2005 08:27 PM
Making speakers cables and interconnects from foil inductors JCoffey Everything Else 4 5th February 2005 12:05 AM
Cardas SE15 speakers cables BTW Chip Amps 0 13th November 2004 02:49 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Page generated in 0.10710 seconds (80.46% PHP - 19.54% MySQL) with 10 queries
