If I take this design and compress it so that it is no more than 9" high, keeping the length of the TL constant, would this work? What about volumn behind the baffle?
Thoughts? My friend has built the matching tower speakers, and a matching center would be sweet. http://users.d-web.com/dbrown/db717tlc/db717tlc.htm It has to fit in a 9" space...... |
#2 |
It will change the CSA of the line if all you do is reduce the vertical dimention but I doubt it will change the response all that much (or enough to worry about). The volume behind the baffle is a part of the line as well, it's not a problem.
I can't see any reason why it won't be fine. |
| Proven DIY Line Array Design? | Ren | Multi-Way | 40 | 3rd June 2011 11:29 PM |
| Most Proven DIY Design? | abefroeman | Multi-Way | 18 | 25th February 2009 11:05 PM |
| Looking for a proven WMTW design or kit for HT L-C-R use | DTS | Multi-Way | 2 | 3rd January 2008 03:11 PM |
| Any Proven Transmission Line Design suitable for FE208Z | vangogh-hk | Full Range | 3 | 1st September 2006 04:52 PM |
| DIY speakers, what is proven | Supertib | Multi-Way | 5 | 22nd December 2005 11:35 PM |
| Page generated in 0.07762 seconds (65.16% PHP - 34.84% MySQL) with 10 queries |
