Old 19th November 2006, 09:49 PM   #1
thadman is offline thadman  United States
Default Servo drive midrange?
I've seen several implementations of servo-drive technology (theres an article outlining it in this months Audio XPress) in subwoofers, but not midranges where we are most sensitive to distortion.
After reading up on these forums, I've come to the conclusion that most distortion from a driver is due to non-linearities in excursion (BL isnt flat).
From my understanding, the servo-drive units (measuring acceleration) apply different amounts of power throughout the stroke making its excursion more linear. Why hasnt this been done for midranges?
Is the active technology inept at responding fast enough in the midrange?
Would it be possible to create a *passive circuit* after measuring a driver (doesnt dayton offer a speaker measurement setup?) and its specific BL curve and applying power at the inverse of the curve (more power at the extremes) to make the BL more flat?
TC Sounds has introduced a *passive* answer to this solution by designing the voice coil around the BL curve (varied amount of windings)...why hasnt this been done on midranges?
Old 20th November 2006, 12:34 AM   #2
We redesigned the magnetics 5 years ago to create a flat BL curve, and have several midranges available with a flat BL curve.
To use a servo would require a VERY wide bandwidth on the servo circuit, and most likely would not be practical in terms of stability and gain-bandwidth product.
Dan Wiggins
Adire Audio
Old 20th November 2006, 12:45 AM   #3
Probably due to the low excursion of mids, the cone moves less so the suspension is design for linearity over excursion, The motor geometry is simpler due to less excursion requirements-so a flat BL curve is easier to obtain than on a long throw woofer.
FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. Dougie085 Swap Meet 0 3rd May 2008 07:31 PM
Servo Drive Sub woofer nbcaudio Subwoofers 2 22nd February 2005 04:22 PM
servo motor for turntable drive Mikewong Analogue Source 2 18th March 2004 08:51 AM
servo motor for turntable drive Mikewong Analogue Source 3 4th February 2004 09:57 AM
Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive kelticwizard Everything Else 12 22nd January 2003 03:34 AM
Page generated in 0.08026 seconds (71.69% PHP - 28.31% MySQL) with 10 queries
