I have this nice sounding pair of Aiwa bookshelf speakers and I want to make them into something better. I know that they can sound better by adding some insulation (at the moment they don't have any). But I want to make it into real diy project by converting this bookshelf set into a floorstanding set and use a decent 3 way crossover. Is this possible or just stupid? ![]() That's sort of what I want to do. I thought isolating the woofer mid, and tweeter would yield the best sound. Any thoughts would be appreciated. Thanks! |
#2 |
Location: kansas city mo, and on occasion, around the world ...
zillions of these all over the planet-
http://list3.auctions.yahoo.co.jp/jp...gory-leaf.html go for it |
#3 |
I have had the same thought. I see a lot of bookshelf systems for sale on Craig's List. Very cheap way to get a set of drivers for a 3-way system (with an amp left over). Let us know how it turns out.
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#4 |
However, Cal Weldon had a somewhat similar sort of speaker at one of Al Wooly's RAW Fest meets a couple of years back. It was pretty unusual, to say the least. It prompted Kevin Haskins of DIYcable/Exodus Audio to grant them "The Terry Olson Award". Depending on your personal take, that might be good...........or bad:^) I'd say that you owe it to yourself get some cardboard boxes for a mockup and try it out. Not much to lose, just don't turn up the volume very high. It "will" give you a rough idea of what to expect and would allow you to experiment (juggle) the placement/distances, etc., of your separate driver enclosures. "When in doubt, try it out!" Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#5 |
Thanks for replies everyone but what I need to know now is how big do the cabinets have to be and to port or not to port? If I do port how big should the hole(s) be? Isn't there some sort of calculator?
Also, what type of wood to use (that is, after I'm done cardboard testing)? |
#6 |
To determine the size of the cabinet, you need to know the specifications of the drivers, like thier Vas, Qts, etc. Do you have any testing equipment?
#7 |
No. I don't have any testing equipment. I have no idea what Vas and Qts are! Ugh. I have such a long way to go!
Where can I start? What do I need to purchase? |
#8 |
If they sound decent now you will very likely make them worse. You have no way of designing a decent 3-way crossover, and it is not possible to buy one, all off the shelf c/o's don't work well. Adding a supertweeter (or is it adding a 2" mid ?), not a good idea. If you want to build a pair of speakers, given the time involved, starting with cheap unknown quantities is not a good idea. Build the floorstanding version of this (28Hz port tuning) : http://www.zaphaudio.com/BAMTM.html |
#9 |
The Aiwa speakers themselves have a 6.5" woofer and 2" mid and 1" super tweeter. I'm not adding anything. Its all there.
EDIT: Also, the Aiwa set still has the XO it came with. So are you saying it is impossible to improve the design of speaker? |
#10 |
Speakerholic
Hi 450,
It sounds like fun and might be a good learning experience. The thing that will hold you back is getting the XO right. That's a pretty tricky thing and if you are still learning about Qt and Vas are then you might want to pull the reigns in a bit and consider what others have said. Rather than try and improve the Aiwa's you might be better off to think about a kit speaker. They are reasonably priced, allow you to get your hands dirty and most of the ground work has been looked after. You still get a tremendous sense of satisfaction and leave behind the heartache of a failed DIY. How are your woodworking skills? |
| Speakers made | jugi63 | Multi-Way | 1 | 30th December 2008 02:40 PM |
| Hey, what if I made my speakers like this? | keantoken | Multi-Way | 13 | 24th December 2008 12:31 PM |
| Bookshelfs made into floorstanders | polkymon | Multi-Way | 4 | 18th January 2007 12:50 PM |
| Who says aiwa doesn't make nice speakers? | dqswim | Multi-Way | 2 | 9th May 2004 07:00 PM |
| Page generated in 0.13033 seconds (80.15% PHP - 19.85% MySQL) with 11 queries |
