Old 19th November 2006, 11:52 AM   #1
felixx is offline felixx  Romania
felixx's Avatar
Default Open baffle for 19m2
My living have 19m2.
After an MLTL with an 214 liters,closed enclosure,Voigt enclosure...I'm thinking on open baffle with my Supravox 215rtf bicone driver.
The sound in OB is far from any enclosure....but I need bass extensions.
It has an fs=52hz and qts=0,53.
My concern is for the right driver for bass.
I'm thinking on Hawthorne Augies 15" bass driver or Eminence Delta 12lf into 60 l closed enclosure or two Peerless SLS 12" on each baffle.The power (rms)(in pdf) of one Peerless is only 100w...should be enough?
http://www.lautsprechershop.de/hifi/...i/peerless.htm
Also I'm thinking to go active for bass drivers.
Any thoughts will be welcome in choosing the right woofers?
"I'm glad I can build my own mistakes."
Old 19th November 2006, 12:54 PM   #2
felixx's Avatar
I search deep and I find sls 12"...have 200 w.
http://www.shop.hellsound.de/index.h...t=dept_71.html
What do you think?
Old 19th November 2006, 02:10 PM   #3
el`Ol is offline el`Ol  Germany
I wasn`t impressed by the SLS12 in combination with 8" fullrangers. I am considering this for bass support
http://www.hm-moreart.de/78.htm
together with a low Mms driver.
Old 19th November 2006, 07:17 PM   #4
felixx's Avatar
what was your combination between peerless sls and what type 8"full range...in what configuration?
Old 20th November 2006, 02:19 AM   #5
It was Ciare HX201 sealed plus Peerless SLS12 sealed. The main problem was that the Ciare sealed doesn`t work. Now it is running in TQWTs down to 60Hz. But the Pearless bass just sounded like conventional hifi, quite boring in combination with the fullrange, so I didn`t try to get the combination running properly.
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Page generated in 0.08972 seconds (72.61% PHP - 27.39% MySQL) with 10 queries
