Old 18th November 2006, 07:27 PM   #1
Default MIT Terminator Speaker Cables - Impedance and Resistance
Okay, I have a 2 pairs of MIT Terminator 5 speaker cables and when measured they all show 2 ohms resistance. So if I use these cables will my amplifier actually see to more Ohms of resistance?
Since my speakers have 6 ohms resistance, does this mean if I use the MIT cables the amplifier will see a total of 8 Ohms resistance?
I ask all this because my amplifier specifications call for a minimum of 8 Ohm speakers when using 2 pairs. Well, my speakers are all 6 Ohm - but if the MIT cables give me 2 more Ohms resistance then I should be fine to hook all 4 speakers up becasue the amplifier will think they are actually 8 Ohm speakers. Right?
Thanks for any help on this.
Old 18th November 2006, 07:50 PM   #2
Speakerholic
Cal Weldon's Avatar
Measure the DCR with the cables attached. If it's 6 ohms or above, you should be OK.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 18th November 2006, 08:22 PM   #3
Send a message via AIM to DigitalJunkie
That seems odd,speaker cables should be a nice low resistance,shouldn't they?
I'm assuming the cables are shorter than 100 feet?
Even cheap zip-cord has lower resistance.
Old 18th November 2006, 08:47 PM   #4
Cloth Ears's Avatar
Ah, yes. But those MIT Terminators have those large 'mysterious boxes attached to them. A cross-over by another name, perhaps? I wonder what the capacitance and inductance measurements would give us also?
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 18th November 2006, 09:01 PM   #5
analog_sa's Avatar
Boxes or no boxes 2 ohms sounds excessive and would dramatically alter the sound of many speakers. I would suspect a wrong measurement or oxidised terminals.
On the bright side, if true, you get inbuilt short-circuit protection
Op amps: output impedance and load resistance mudihan Chip Amps 17 20th April 2009 08:09 AM
Tubes load resistance and output trans impedance Jeffy74 Tubes / Valves 3 24th May 2004 11:48 PM
Impedance and Resistance newbie1 Parts 4 15th January 2004 09:43 PM
A question on v coil resistance (NOT impedance) Fossil Multi-Way 3 29th August 2002 04:27 AM
Page generated in 0.08305 seconds (76.80% PHP - 23.20% MySQL) with 10 queries
