Old 17th November 2006, 07:52 PM   #1
kubi is offline kubi  Germany
Default jordan jx125 + jxr6 from vented to closed
Hi there!
I'm going to modify my vented loudspeakers (Jordan JX125 + JXR6) to closed ones to save space in my living-room. Currently it's about 70L per box just for the woofer, which I want to down size as much as possible.
So, I'm talking about the JX125 woofer only.
My idea was to have a closed, high pass filtered design. Qtb = 0.93 would do the job instead of the way lower Qtb at the moment. The distorted frequency response due to the too small box would be corrected with the help of a cap in series with the JX125 driver - the tweeter will remain in its own housing.
According to the formula I know for closed and HP filtered boxes,
V=Vas/((Qtb/Qts)^2-1)
f3=0,7fs/Qts
C=265000*Qts/Re/fs
with
fs=30Hz
Qt=0,45
Vas=53,66l
Re=6Ohm
(from http://www.ejjordan.co.uk/diy/bass)
I end up with
V=53.66L/((0.93/0.45)^2-1)=16,4L
F3=0,7*30Hz/0,45=46,7Hz
C=265000*0,45/6Ohm/30Hz=662,5µF
Good idea or completely crazy brainfart? 17L sounds good to me.
Please let me know what you more experienced guys think before I take apart my current loudspeakers.
BTW: Currently the system is bi-amped (4 x gainclones) with active crossovers (Linkwitz-Riley filters @500Hz, 12dB/Okt). I want to keep that amp for the new boxes. It's cheap (gainclones ), but it's still very good and allows me deep adjustment of all the parameters to make the two drivers match together. That's easier and cheaper than building a decent passive XO, since I'm more an electrician than loudspeaker builder.
Thanks in advance!
Old 17th November 2006, 09:08 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
I got f3= 50,5 Hz and fc=62 Hz for a Qtc of 0.93 at V=16.4L.
I believe that Vb= 36L; Qtc=0.71 and f3=Fc=47 Hz is a better choice from the transient responce reasons.
B
Jordan JXR6 HD and JX125 NG available to order. mdikovics Full Range 3 12th March 2009 12:58 PM
jordan jx125 beckypumps Full Range 8 29th August 2007 11:28 AM
FS single jordan jx125 pamaz Swap Meet 3 6th February 2007 03:31 PM
wtb jordan jx125 pamaz Swap Meet 6 27th April 2006 06:32 AM
FS: 2x Jordan JX125 digitoxin Swap Meet 1 10th April 2006 05:11 PM
Page generated in 0.07333 seconds (65.23% PHP - 34.77% MySQL) with 10 queries
