Old 29th November 2006, 08:25 PM   #11
Sonusthree's Avatar
Originally posted by whats gan on
hi i am not sure all the opamps are for the phono someone told me two were for the pre section ..........
Hi again and thanks for the diode info. Did it make a big difference?
All of the opamps are for the phono section only. Some people refer to this as the 'pre' and this can be slightly misleading. Anatech (Chris) has reliably informed me that the phono section is prone to oscillation and instability whch can affect the main section. Obviously this is not good but is easily remedied. You really should read this thread since Anatech repaired (repairs) these amps under warranty from Cyrus so he knows his onions.
Cyrus Two low input impedance?
The Cyrus One and Two have completely passive preamps. They are basically a low pass and high pass filter and a potentiometer.
Back on topic:
I wonder if you would get more bass if you removed the plinths? I made my plinths by taking the full sized stands from 609's or similar and removing the central metal shaft. (Anyone need one?)
I then glued and screwed the top plate to the base so perhaps my plinths are more lossy than the originals? Just a thought.
Martin
Old 29th November 2006, 09:17 PM   #12
thanks martin i will take of the plinths tomrrow they are ugly anyway lol thank you for info on the preamp i will remove the opamps and see what improvements they make i could also remove all the power supply to them bye for now mate off to bed
Old 29th November 2006, 09:25 PM   #13
Sonusthree's Avatar
Removing the two regulators is the best bet.
That completely eliminates the problem unless you need a Phono preamp.
Nighty night!
Old 30th November 2006, 08:39 AM   #14
i will thank you did you get my email i sent you so i can send you pics of the 615s crossover
Old 30th November 2006, 09:06 PM   #15
Sonusthree's Avatar
Nope
Old 30th November 2006, 10:29 PM   #16
hi martin here it is kieran_2004@msn.com
Old 5th December 2006, 01:52 PM   #17
inrank is offline inrank  United Kingdom
inrank's Avatar
there are a pair on ebay atm btw.....
http://cgi.ebay.co.uk/TANNOY-615-FLO...QQcmdZViewItem
Old 5th December 2006, 02:28 PM   #18
Sonusthree's Avatar
If only I was closer..........
These Tannoys don't seem to travel well at all.
Old 5th December 2006, 07:47 PM   #19
HI I OWN A PAIR OF THESE AND THEY ARE WELL WORTH TRAVELING FOR I PAID £150 MINT WHAT A BARGIAN
Old 1st January 2007, 10:02 AM   #20
Default Tannoy 6 Series
Martin,
You seem to know a lot about the Tannoy six series, and stated that you had electronic copies of manuals for all of them. I'm a new member, still under moderation, so can't email you. I wouldn't mind an email copy of the 609 manual though.
I have a pair of Tannoy 609's (bought second hand in 1992 in Plymouth). Do you know how can I ascertain if these are Mk1 or Mk 2? There are no markings or labels on the speaker boxes (apart from their serial numbers).
Also, do you know where I can source replacement speakers? I suspect that one of my tweeters may have blown.
Many thanks,
Mike
tannoy 611 mk2 whats gan on Multi-Way 6 29th August 2011 09:38 PM
tannoy 615 mk 11 tricia Multi-Way 0 26th July 2009 10:12 PM
Tannoy 609 compared with Tannoy 615 photomusicfreak Multi-Way 4 27th November 2008 10:27 PM
Tannoy TS8 inrank Subwoofers 0 12th May 2006 01:34 PM
Tannoy i12 set of three RHosch Swap Meet 4 17th May 2004 07:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
