Hi all.
I am slowly finishing my speaker project from zaohaudio.com, it is the L15RLY/P-27TFFC system, but in different enclosure (have pictures, when i find cableto camera, will post).I am considering extend the bottom a little bit.Lets say i can have 33L enclosure, and would like to use these Peerless drivers (2 each side): http://www.tymphany.com/datasheet/printview.php?id=355 Any suggestions? Thanx for replay P.S.: the enclosure would have the same shape as the small system, and would be used as a stand aswell...... Exceuse me...........Mr. ZaphAudio........... |
#2 |
I have not used the SLS but Peerless in known for its excellent bass performance. I think two SLS 6,5" (or 8")will give you a good performance at a good price. A suggestion is to use an active filter => much better performance!!!
Also Linkwitz is using the 10" in the Pluto+ sub. http://www.linkwitzlab.com/Pluto/subwoofer.htm Ps You say 8" in the subject but the link is to the 6,5" SLS |
#3 |
oh....my error...it is 6.5" ofcourse.You see, the front baffle on the cabinet is only 195mm wide, so i can use only woofers/midwoofers in this size.It is only to extend the bottom.I cant acommodate 10" subwoofer, and to use 2 Peerless drivers in 65cm high enclosure will save me some space.It will also serve as a stand.
Thanx for replay. |
#4 |
how do you intend to implement the crossover ? |
#5 |
Hi. Until the bass section is not finished, i will use ZAPH's x-over.And then Active XO with the bass section.So til that point i have to learn how to make Active xo's
#6 |
Active it is then, I hope you are making the top section sealed. the 2 drivers you suggest at a total Vas of 24L are not ideally suited to a 33L (internal volume) cabinet. You could use 2 drivers either side in force cancelling mode. Do you want sealed or reflexed for the sub section ? What power goes to the main speakers ? Using a sub amplifier or another amplifier or a HT amplifier ? |
#7 | |
The top section will be probably sealed, i have 33 liters of volume to play with for the bass section, so it can be anything in this range.Its no problem to seal it off to any volume. The power to the speakers will not excede 50-60W, i like easy listening levels... The amp is Marantz 7001 and the source is RPM 4 turntable and Marantz CD5001.And for the bass section i think rotels RA series power amp. |
| 2 inch Peerless vs 2 inch HiVi Research | richie00boy | Multi-Way | 18 | 5th December 2007 08:31 PM |
| FS: Peerless 10-inch 831727 | jmikes | Swap Meet | 0 | 12th March 2007 02:11 PM |
| Peerless 5.5 inch drivers for sale | tomcat9 | Swap Meet | 0 | 16th September 2005 04:40 AM |
| Peerless CSX 10 inch in sealed box or TL? | ashok | Multi-Way | 12 | 23rd January 2004 11:24 PM |
| Page generated in 0.11361 seconds (71.36% PHP - 28.64% MySQL) with 11 queries |
