Old 16th November 2006, 12:52 AM   #1
bawang is offline bawang  Malaysia
Default Reducing output of tweeter
Finally, I am about to jump into the world of DIYing your own speaker sets. But before that, a simple question to all the DIY masters here, "How do you reduce the output of the tweeter without affecting the crossover point?"
I want to use a passive corssover, in a 2-way system. The tweeter has a sensitivity of about 4dB higher than the woofer. Impedance of tweeter is 5 ohm, woofer 8 ohm. Crossover point selected is around 3kHz, which means a capacitor value of about 10uF (tweeter) and inductor value of around 0.45mH (woofer) for a first order crossover.
I don't want to use an L-pad. I know that sensitivity can be reduced by padding with power resistors (wastes the available power, but acceptable to me). But where should I put the resistors? Before the tweeter cap? Am I on the right track?
Thank you.
Old 16th November 2006, 01:13 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
I put the series padding resistor before the cap. Make sure you use a 5W resistor.
No longer DIY active
Old 16th November 2006, 01:27 AM   #3
Thanks a lot, rabbitz. Greatly appreciated. Any ideas on the resistance so that the sensitivities of the tweeter & woofer will be the same?
Reducing output transistors gruni Solid State 26 6th July 2009 03:22 PM
Reducing volume of planar tweeter tubesmuggler Planars & Exotics 3 17th November 2008 05:52 PM
reducing output Lostcause Power Supplies 4 7th September 2006 09:50 PM
Reducing Audio Line Output? freezz Everything Else 12 29th June 2005 11:48 AM
Reducing output voltage macce78 Chip Amps 16 17th January 2004 09:21 PM
Page generated in 0.07882 seconds (68.77% PHP - 31.23% MySQL) with 10 queries
