Hi, my Woofer (Seas CA25RE4X/DC) has 2 sets of terminals?
Aparently it has 2 layer voice coil with seperate terminals. Do I just connect to one set of terminals? Any help appreciated. Sam. |
#2 |
Functionally, yes, you could connect to only one set. Ideally, both should be used, as this will provide the full efficiency of the woofer. 4ohm load for a parallel connection and 16ohm for a series connection. The T/S provided by seas is for a parallel connection. Using a series connection would change the electrical parameters. Using only one of the coils would change the electrical and mechanical parameters.
http://www.seas.no/seas_line/woofers/H372.PDF |
#3 |
thanks tuukka,
unfortunately I designed my crossovers asuming the woofer was an 8ohm driver, so I would only connect to one set of terminals? Would that compromise on the characteristics of the driver and not perform to its max capabilities? |
| FS/FT Distortion sets | markdesmarais | Swap Meet | 12 | 20th March 2009 02:15 AM |
| Tri-amp using 2a3 SETs | marcutan | Tubes / Valves | 13 | 2nd March 2008 10:49 AM |
| Opinion on 300B SETs | korneluk | Tubes / Valves | 1 | 4th January 2008 10:56 PM |
| Help needed with 805 sets | georgehifi | Tubes / Valves | 4 | 18th February 2004 08:35 PM |
| Page generated in 0.06861 seconds (69.59% PHP - 30.41% MySQL) with 10 queries |
