Old 15th November 2006, 06:09 PM   #1
Default Driver spacing ... ?
Hi all,
What do you think of that:
Driver spacing? Try to keep the dimensions of the mid and tweeter chambers less than the length of a wave at the crossover point. The table on the left lists wavelengths at different frequencies.
5000 Hz 2.7 in
3000 Hz 4.5 in
1500 Hz 9.0 in
750 Hz 18.1 in
500 Hz 27.1 in
300 Hz 45.2 in
200 Hz 67.8 in
100 Hz 135.6 in
http://www.lalena.com/Audio/FAQ/Build/
Thanks,
REALFLEO
Old 15th November 2006, 06:49 PM   #2
I see sense in his other suggestion to keep driver to driver spacing small. It all about beaming and lobes and uneven off axis response.
I cannot see a reason for limiting the internal dimensions of the back boxes.
Have you a clue to why this would be an advantage?
regards Andrew T.
Old 15th November 2006, 07:07 PM   #3
You should also keep the centers of 2 drivers within the length of a wave at the crossover frequency. Also note that a speaker producing frequencies of a wavelength less than its effective diameter will be very directional at those frequencies.
I think it's also to limit stationary wave but I'm not sure and that's why I'm asking your opinion .
Thanks,
REALFLEO
wmtmw driver spacing kifeinthesink Multi-Way 6 6th April 2010 11:08 PM
Driver Baffle Spacing vdi_nenna Multi-Way 3 22nd April 2008 11:02 PM
driver spacing memphissound Multi-Way 7 21st August 2006 03:29 PM
3-Way Driver Spacing 69stingray Multi-Way 4 24th June 2005 02:13 AM
is driver spacing important ? busterno1 Multi-Way 12 9th February 2004 06:28 AM
Page generated in 0.06662 seconds (82.73% PHP - 17.27% MySQL) with 10 queries
