Old 15th November 2006, 03:01 PM   #1
alexcd is offline alexcd  United States
alexcd's Avatar
Send a message via AIM to alexcd Send a message via Yahoo to alexcd
Default 1/8" MDF - where to buy around MA/NH?
So I wanted to start a project using 1/8" MDF because I heard it is capable of bending significantly (2-3ft radius.) I would like to use this bent over a frame to create my enclosure. Where do I get this? Home Depot doesn't seem to carry it. I'm in MA/NH if that helps.
Old 15th November 2006, 03:51 PM   #2
Check out Boulter Plywood in Sommerville, MA.
I didn't see 1/8" MDF listed but they have a few otehr options in the Flexible Plywood section of their website.
Old 15th November 2006, 03:55 PM   #3
alexcd's Avatar
So, is the concensus that local places are better?
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 08:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.07832 seconds (69.26% PHP - 30.74% MySQL) with 10 queries
