Old 27th December 2002, 12:14 AM   #11
frugal-phile(tm)
planet10's Avatar
Originally posted by Jimmy154
What's the avantages of an array like that?
Increased sensitivity & in the nearfield it has a level fall-off of 3 dB per doubling of distance as opposed to the 6 dB from a point-source.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th December 2002, 12:20 AM   #12
diyAudio Moderator Emeritus
roddyama's Avatar
Dana,
Fantastic. They look like a lot-o-fun.
BTW, you can use the El Pipe-Dopo name if you like. That is, if you haven't already given them a few choice names.
Rodd Yamashita
Old 27th December 2002, 12:49 AM   #13
Rod,
Thanks for the kind words and the offer. I have considered the old standby's "Tubal Legation", "Bjork Pipe" and "Lou Alcylinder", but I think that I will settle on "L'Tubage de Catpole".
Old 27th December 2002, 01:29 AM   #14
frugal-phile(tm)
planet10's Avatar
Here is an extract from dana's pdf. The pictures are quite detailed and i suggest anyone really interested get the pdf. I'm off to dinner but will put it up for downloading after.
dave
Old 27th December 2002, 02:03 AM   #15
Dave, do you have a link to that PDF?
Thanks,
Rob
Old 27th December 2002, 03:41 AM   #16
frugal-phile(tm)
planet10's Avatar
MLsub.pdf {350k}
dave
Old 27th December 2002, 03:43 AM   #17
frugal-phile(tm)
planet10's Avatar
dana,
What driver are you using in the sub?
dave
Old 28th December 2002, 12:15 AM   #18
Dave,
The drivers are from Professional Audio Systems (LX-2800), and were a Christmas gift a couple of years ago from an extremely generous friend of mine.
Specifications:
Diameter: 470 mm (18.5 inches)
Nominal Impedance: 8 ohms
Frequency Range: 30 Hz to 1 kHz
Highest Recommended Crossover Frequency: 500 Hz
Power Capacity: 600 watts
Sensitivity: 98 dB (@ 2.83v @ 1m)
Voice Coil Diameter: 99.3 mm (4 inches)
Voice Coil Material: edgewound aluminum
Winding Length: 27 mm (1.063 inches)
Former Material: Kapton
Magnetic Gap Length: 8 mm (0.315 inches)
Magnet Weight: 2.85 kg (6 lb 4 oz)
Magnet Assembly Weight: 9.06 kg (19 lb 15 oz)
BL Product: 22.6 Tesla Meters
Effective Piston Diameter: 0.39 m (15.35 inches)
Maximum excursion before damage: + 19 mm (+ 0.75 inches)
Re 4.6 ohms
Qts 0.226
Qms 2.28
Qes 0.251
Vas 425 L (15 ft3)
Cms 210 µM/N
Mms 160 grams
Mmd 138 grams
no 3.38 %
Le 1.6 mHy
Large Signal Parameters:
Sd 0.1195 m2 (185 in2)
xmax + 12.7 mm (+0.50 in)
Vd 1520 cm3 (93 in3)
Mounting Information:
Diameter: 470 mm (18.5 in)
Bolt Circle: 438 mm (17.24 in)
Baffle Cutout: 422 mm (16.6 in)
Depth: 206 mm (8.12 in)
Net Weight: 12 kg (26 lbs 5 oz)
Shipping Weight: 13.5kg (29 lbs)
Features:
Heavy ribbed cone
Highly damped EPDM half-roll edge (that looks like a Schwinn inner tube)
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
Line array help Fazorcat Multi-Way 12 13th March 2005 04:02 PM
Line array tweeter line - On left or right? dhenryp Multi-Way 4 9th March 2005 11:35 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Help with line source array subs!?!?! Turboegt Multi-Way 12 29th December 2003 04:02 AM
Page generated in 0.11178 seconds (76.38% PHP - 23.62% MySQL) with 11 queries
