Hi
I am approaching the end of my floorstander build (Scanspeak 18W/4531 + D2904/7000) based upon an AOS design and crossover. It is still possible to tilt the speakers back by say 5 degrees if I like, as I have included a laminated spacer between the speaker and its foot, which can be planed into an angle. I have seen many designs that tilt backwards by 5-10 degrees. What is the benefit on this? Could/should I do this with mine? There is no time dealy in my crossover. TIA. Michael |
#2 |
Did it Himself
It's usually to to try and achieve some kind of time alignment between drivers.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
There is a good time alignment discussion on here that went on for several pages if you want to search for it, I'll summarize what I think is key:
The more overlap in freq. response between drivers the more important the time alignment, ex. full range mid-woofers with a high passed tweeter. I listened to some new speakers I bought for a budget mtm (above config.) and was able to clearly hear ~1/4" mis-alignments. Not very scientific but the results were not subtle so I feel comfortable with the above generalization. Whereas some users in the above mentioned post discussed studies where several cm were not noticeable with a 4th order LR network. I recommend a switch and two completed towers next to each other, switch back and forth with one tower shimmed and one level and listen. I will bet that if you have a high order xover you wont hear any difference. |
| Back to Back transformers and safety ground | dsavitsk | Tubes / Valves | 1 | 9th February 2009 10:10 PM |
| 3 Way floorstanders | jjbmon | Multi-Way | 3 | 26th January 2008 08:45 PM |
| Marantz SR-840 won't turn on without tilting up at 90 degrees | beerman | Everything Else | 1 | 29th March 2007 07:45 PM |
| My new floorstanders- | nate | Multi-Way | 13 | 31st October 2006 02:27 AM |
| (Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions | paulspencer | Multi-Way | 9 | 15th August 2004 05:34 AM |
| Page generated in 0.06866 seconds (72.79% PHP - 27.21% MySQL) with 10 queries |
