Old 12th November 2006, 08:22 AM   #1
ka7niq is offline ka7niq  United States
Default Crossover Help And Opinions Needed
I am using 2 Audax HM 1030 Carbon Fiber mids and a Morel MDT 37 Tweeter in a MTM configuration.
I wisg to use a simple first order crossover between the mids and tweeter.
I have an adjustable electronic crossover for the crossover point between the 15 inch woofer and midranges.
The midranges are 12 inches vertically apart, center to center, and the tweeter is 1/2 way in between, vertically.
The baffle is really wide, almost 28 inches, and the drivers are centered onn it, and the center of the array is ear level to a seated listener.
The Audax HM 1030 is a real wide range driver, and I was wondering HOW far up in frequency I could take it before the 12 inch vertical spacing becomes a problem ?
I would be interested in some crossover ideas and recommendations.
If possible, I would like to only use first order crossovers because I would like to keep it simple.
Old 12th November 2006, 09:28 AM   #2
Geoff H is offline Geoff H  Australia
From what I see, the MTM is vertical.
The freq of the chosen x-over should not have much to do with the vert spacing. Vertically alligned drivers will spread the HF horizontally, rather than a single driver beaming it.
You could probably let the Audax's roll off naturely, crossing over at the -3db point.
I am not familar with the Audax, how high does it go?
Old 12th November 2006, 01:49 PM   #3
It will go out really far, past 10K.
But I have a tweeter, and it would be beaming up at 10K
Crossover Help/Opinions DerrickM Multi-Way 16 27th March 2007 03:45 PM
3 floorstanders-opinions needed mlankton Multi-Way 3 12th September 2006 12:35 AM
Crossover point for Scan-Speak Drivers - Opinions needed ShinOBIWAN Multi-Way 50 27th March 2005 01:25 PM
Opinions on this crossover? Fryguy Multi-Way 4 3rd August 2004 08:27 AM
X2Y caps opinions needed deskmate88 Digital Source 8 2nd June 2004 04:23 PM
Page generated in 0.07851 seconds (69.69% PHP - 30.31% MySQL) with 10 queries
