What type of box is this ( winISD ) - diyAudio
Old 12th February 2001, 11:17 AM   #1
I have a couple of Earthquake BR1270 ( 8 ohm ) subs.
I have been working on a box that is isobaric but a 4th order bandpass.
If you have winISD and look at the picture of a 4th order box it has 2 chambers, the front ( with the port in it ) and the back chamber wich is like a sealed chamber.
now I want to have this type of box but use another seale chamber on the front of the ( front chamber ) and have the 2nd sub fire into it aswell as the 1st sub that fires into it from the oposite chamber.
to me this would be an Isobaric 4th order.
So if using winISD should I choose an Isobaric 4th order ????
Please email suggestions
Matt P J
Old 15th February 2001, 01:14 PM   #2
blmn is offline blmn  Brazil
blmn's Avatar
mattpj,
I think you could consider two simple 4th order designs with a common duted chamber.
I think you can also consider 2 times the volume for a single speaker design in the duted chamber and two ports.
If you need just one port in the commom chamber you have to do some calculations (or use your software to do this if it has this possibility). Any good loudspeaker cookbook (like Vance Dickason´s, for example), has the equations and more information about your question.
Be carefull with the polarities of speakers to achieve the best perfomance.
Old 23rd November 2009, 09:10 PM   #3
tiefbassuebertr's Avatar
So if using winISD should I choose an Isobaric 4th order ???? Please email suggestions
Thanks Matt P J
Are there photo sessions of this construction?
Winisd help Buzzy Subwoofers 5 28th June 2007 09:01 AM
Re : BL type & GR type of transistor for Aleph-Ono Arion Pass Labs 4 29th January 2007 06:15 PM
WINisd Help... jakelm3075 Subwoofers 6 10th May 2006 01:54 PM
Help with WinISD and XLS 12 Glen1 Subwoofers 19 6th December 2005 02:11 PM
beyond winisd.... ChesterFuzzin' Multi-Way 1 9th January 2003 03:06 AM
Copyright ©1999-2017 diyAudio
