Old 9th November 2006, 04:56 PM   #1
alexcd is offline alexcd  United States
alexcd's Avatar
Send a message via AIM to alexcd Send a message via Yahoo to alexcd
Default Vifa/Dayton/Dayton... First speaker for me, finally!
Here's the plan so far...
TMWW
Midbass/Woofer = 2xDayton RS270, 30-600Hz
Midrange = Dayton RS52, 600-2.5kHz
Tweeter = Vifa XT25, 2.5kHz-40kHz
My restrictions is that the above mentioned drivers need to be powered by LM4780 or LM3886 gainclones. I have already built one of these amps and it sounds amazing. I will also be using an active crossover design ala Linkwitzlabs.
Another driver to replace the midrange and lower the tweeter XO point is the Peerless 5.5" exclusive but this significantly lowers my total efficiency which may be a problem with the gain clones.
Usher 9845 2" Textile Dome Midrange??
I am also trying to do this under a tight budget. Comments?
Old 10th November 2006, 01:20 AM   #2
Regarding the budget issue, Hi-Vi DMB-A mid domes only cost about $25 each and they are reportedly superior to the Usher, with similar specs frequency wise. Sensitivity is 92dB
Old 10th November 2006, 01:54 AM   #3
alexcd's Avatar
Wow, those are a good deal.
Zaph has some small drivers measured on his page and that is one of them. The RS52 seems to have a flatter response and lower distortion. I guess that's the trend with those aluminum Daytons (low distortion.) But, is that the end all of making a decision? I'm an engineer by trade so I'm used to pick things by specifications. Audio is not so easy.
Old 10th November 2006, 02:21 AM   #4
v-bro is offline v-bro  Netherlands
v-bro's Avatar
A first speaker and allready a three way eh?
For the same budget I think there are better sounds achievable...
And a lot easier to start with, a two way....
Or will you copy some kind of design?
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 10th November 2006, 12:31 PM   #5
alexcd's Avatar
This is the first design that I've done and actually kept it for myself. I've done two 2-ways, one 3 way (active crossover,) and countless subwoofers. So I'm not a noob by most people's standards.
There a benefits to 2ways and 3ways. I am trying to minimize Doppler distortion by using a dedicated midrange. It's nice to get opinions about drivers that people have used. That's what I need in this case.
I'm looking for a natural, smooth but dynamic with no slop type sound.
Old 11th November 2006, 05:00 AM   #6
v-bro's Avatar
In this respect I prefer planar units...
I've once listened to 3-way ACR isostatic RP200 speakers, very convincing true, natural, detail, imaging, dynamic and timbre. (two 20cm woofers and two Swiss made magnetostatic devices for midrange and highrange) They weren't expensive, but a bit higher budget than your plan....
But ESLs........
On the other hand I do read very positive things about that xt25, but usually prefer cone midranges...http://www.diyaudio.com/forums/showthread/t-55859.html
I do own two vifa 75mm domes, but they're real crap...
Dynaudio d52 mmmmmm! , but I guess they're not around anymore...
Cheers!
Old 29th November 2006, 10:54 PM   #7
Jay_WJ is offline Jay_WJ  United States
I'm thinking of a similar project to yours. I also chose the RS52 but XT19 as a tweeter for better off-axis response. The tweeter crossover will be around 3kHz to 3.5kHz. I think 2.5kHz for your XT25 and RS52 is a bit lower than ideal.
Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? wigginjs Multi-Way 6 3rd March 2008 08:56 PM
Dayton,Audax, Vifa 3-way rinx Multi-Way 6 20th November 2007 03:14 AM
Dayton DA aluminum cone woofer + Dayton DC28f tweeter springy101 Multi-Way 7 15th March 2006 05:22 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Dayton Reference (RS) Aluminum drivers finally out Hybrid fourdoor Multi-Way 32 12th October 2004 03:15 PM
Page generated in 0.09019 seconds (74.99% PHP - 25.01% MySQL) with 10 queries
