Just thought I would let everybody know about a situation that has happened several times -
On the BSS FDS 366 digital crossover - several home brew and kit amps have refused to run correctly. They have unlistenable large amounts of distortion one time the problem was solved by putting 1 to 1 transformers in line. It appears that the BSS unit needs transformers in-line or DC blocking caps on the amp inputs to block DC coming in on the inputs. Many (most?/all?) factory amps will sloutions to block DC at the inputs, but it will likely not be the case with homebrew. I am aware of similar problems with a DEQX. Since this has caused some grief due to not understanding what was going on, I thought it a good idea to make a post about it. Figured loudspeaker forum would be the correct place since that is where the digital crossover stuff is usually posted. Regards Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
| DC Blocking caps on BPA200. Electrolytic? | Arx | Chip Amps | 5 | 15th June 2007 06:09 PM |
| TTL to SPDIF DC blocking caps | alexg | Digital Source | 1 | 3rd December 2006 02:46 AM |
| DC blocking caps for line level | Tenson | Parts | 2 | 30th October 2006 04:35 PM |
| Noob needs help..Adcom GFA-545 DC blocking caps | need4speed | Solid State | 12 | 14th September 2005 02:54 AM |
| Are huge DC blocking caps on Zen ok? | Arx | Pass Labs | 13 | 3rd November 2003 07:38 PM |
| Page generated in 0.08886 seconds (71.95% PHP - 28.05% MySQL) with 10 queries |
