Old 5th November 2006, 11:11 AM   #1
Default altec 414/comp driver crossover
hey all--
looking to see if anybody out there has got experience with an altec 414 8ohm (b in this instance), and a passive XO centered somewheres around 1k- first or second order is fine. really, what i need is to find impedance curves to try to extrapolate what precisely is going on- in theory- with my crossover at xo frequency.
no impedance info for one driver.. no idea what the real crossover freq. is!
i've only got sonics to rely on- and despite being happy with the midrange- i'd still like to see if theres room for improvement.
currently, the driver is in a 3.6 cu ft. ported box tuned to 32hz.
the present layout of the crossover is-
bms 4552nd-- 16.8 uF main cap- lpad- 5uF compensation cap across postive terminals of the lpad (for horn rolloff)
altec 414 8b- 1.2 mH inductor.
what i THINK is going on: BMS at 1080 hz crossover- 9.25 ohms.
altec at same- at 8 ohms
BUT- is the altec stable at 8 ohms at crossover for a box of this size?
thanks for any input!
yrs
d.
Old 5th November 2006, 03:15 PM   #2
moamps is offline moamps  Croatia
Hi:
In the picture below you may find the impedance/phase graph of an Altec 414/8 I messed with a while back. I think you may need a measurement microphone and some software to be able to tune the system properly.
Milan
Old 5th November 2006, 04:54 PM   #3
mo!
that's EXACTLY what i was looking for! what sized cabinet did you measure this in?
you are the man!
d.
Old 5th November 2006, 05:31 PM   #4
If my memory serves me correctly, I believe it was a free-field measurement of TS parameters, no box.
Milan
Old 5th November 2006, 08:36 PM   #5
hey mo or other passive users--
with a driver running 4 ohms over nominal at XO-- what would be the ramifications for a 1st order's inductor? by the looks of it-- it brings the value up to 1.8mh or thereabouts for a similar frequency-- but i'm not sure how to calculate an inductor's value in this instance-- is it based on the crossover impedance, the nominal, or some sort of average of the two?
any ideas?
thanks much!
d.
1" driver recommendations for Altec 811 horns Yaho Multi-Way 11 16th September 2008 03:01 PM
TL design for Altec 604H driver cesout Multi-Way 37 30th June 2007 01:34 PM
One Altec Horn with 802C driver + X-Over Zero Cool Swap Meet 2 27th March 2007 01:15 AM
si t amp with altec model 288c driver. tade Class D 13 12th May 2006 11:00 AM
JBL 2431H comp driver mobyd Multi-Way 1 20th March 2006 01:13 PM
Page generated in 0.09268 seconds (71.56% PHP - 28.44% MySQL) with 11 queries
