Old 5th November 2006, 12:35 AM   #1
lndm is offline lndm  Australia
Default Baffle step phase respose
I am working on a baffle that at its extremes comes in from a flat half space section, to a quarter space section (flat baffle in a corner), as opposed to the normal half space into free space.
I am using baffle simulation software, which appears not to be designed for this. I am inverting the response it gives so there is an upward step of 6dB. I am assuming this is reasonable, if I'm wrong, please say so.
My real question is should I also mirror the phase response of the baffle around the 0 degree line?
Old 7th November 2006, 11:02 AM   #2
bump
Old 7th November 2006, 01:00 PM   #3
jackinnj's Avatar
You might want to take a look at the paper "Fundamentals of Difraction" by J.R. Wright -- it was in the Journal of the Audio Engineering Society, May 1997, p347. The paper corrects some of the errors previously published in the JAES.
Old 7th November 2006, 03:13 PM   #4
Quarter space to half space in a corner ?
Baffle step is going from free space to half space.
Two walls are 1/4 space, adding the third wall = 1/8 space.
I can't see that you'd get any baffle step.
/sreten.
Old 7th November 2006, 07:48 PM   #5
Svante is offline Svante  Sweden
Svante's Avatar
Hmm, I don't understand the question either. Maybe a drawing would help. What simulation software are you using?
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 7th November 2006, 09:00 PM   #6
Imagine a corner, and insert a tall, 2' wide panel into it so it chamfers the corner. Ignore the floor and ceiling for the moment.
I figured that small waves contained on the baffle would be in half space, and once extended between the two intersecting walls, they would be in quarter space.
Sorry, in retrospect I don't like my wording on the first post either
I am using The Edge.
Old 8th November 2006, 10:57 AM   #7
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
If I understand correctly, baffle step would not be an issue as it's operating in 2PI.
No longer DIY active
Old 8th November 2006, 11:15 AM   #8
A corner as I see it, before floor or ceiling come into it, is like an orange with a quarter wedge removed or in other words, PI space. If sound from a normal box is considered to be in 2PI space whilst wavelengths are small enough to fit on the baffle.....unless I've missed something?
Svante, kudos on The Edge. I used to use a spreadsheet, but I find your program is easier to set up, easier to manipulate, covers a wider frequency range and has phase information, unlike the spreadsheet.
Old 8th November 2006, 11:29 AM   #9
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Is that the phase of the compensator or the phase of the edge diffraction?
Hear the real thing!
Old 8th November 2006, 11:31 AM   #10
rabbitz's Avatar
Ah.... I see. PI space it is and no baffle step for sure.
Close proximity to the corner I'm sure will give some strange boundry effects with boosts (up to 150Hz?) and suckouts (331Hz?).... thinking aloud
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
What is the effect of Baffle Step on the Phase? Bricolo Multi-Way 4 25th July 2007 05:58 PM
baffle Step rgrayton Full Range 33 4th December 2004 11:16 PM
Page generated in 0.11616 seconds (79.21% PHP - 20.79% MySQL) with 10 queries
