i has any one modified these speakers i would love more bass from them
#2 |
Nope never modded them...
A sub might help? Filter some of the bottom octave(s) out on the tannoys and they will be able to handle more power=more bass output (in the end result).
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#3 | |
In a stereo setup we have FOUR 8 inch drivers working below 250Hz!! This should be enough to loosen any recent dental work. The cabinets are a decent size too so what is the problem? Higher power amps are seemingly helpful for the quality of bass but not the relative quantity. I have the same problem with my MK1's. Firstly, I found that removing the tannoy plinths helped. My plinths are not the originals but are modified from 609 (etc) stands so your mileage may vary. These plinths and stands are mainly made from what looks like compressed cardboard!!! Removing these gave a noticable improvement in my case. Not magic but a definite improvement. I guess that solid floor coupling helps. Sand in the base cavities helps to tighten up what bass is already there but no increase was noticed. I have experimented with cabinet stuffing to increase effective cabinet size with no great change, although it did help to dampen the midrange near the crossover frequency. I own the MK1 and I don't think this a real problem with the MK2. In fact, in a straight shootout the MK2 had more apparent bass. The MK2 611's in my test had the same bass drivers. Yours may be slightly different at least in model number. The Mk1 and MK2 IMO are both too forward but in different ways. Acoustic music lacks bass. It's all there and it is effortless but the balance is just completely wrong somehow. Try some double bass or indeed drum n' bass and you quickly realise that these speakers can really pump bass as low and as loud as you could ever want. It's just not balanced. I don't have the room here but, given their shape and Tannoys history, could they be intended for corner placement? I've never heard this mentioned but you never know! What could be the problem here? What's gan on: Sorry for posting in all you threads but I am your internet stalker!! Regards, Martin. |
#4 | |
The shape of the 611's and the others from the range was never about placing them in corners. The idea behind the shape was to do with internal air movement. A conventional speaker has a single backboard, as the driver moves, the air within is compressed, very much like a piston, the air has only lateral movement ie backwards and forwards. With the 6 series, there are 3 backboards or to be more specific 1 backboard and 2 angled. From memory this theory was included in the literature available when new, Tannoy were trying to evolve speaker systems further and they felt this was a revolutuionary concept. I own a pair of 611's and have done since new in 1991. I have a son aged 17 (speakers are older by a month or so). My son must have been 2 at the time, it was a Sunday and I was reading my newspaper and not paying enough attention to him, I looked up from my newspaper and to my horror, there was my son standing with the big black plastic dust cap from the passive driver which he had managed to prise off and a big smile on his face. Luckily for me Tannoy are/were based a couple of miles up the road, I paid them a visit taking my broken driver and was given not only a tour of their facility but also a replacement driver free of charge. Was thoroughly impressed with everything Tannoy. I still use the 611's daily and just recently replaced my Cyrus IIIi with an Audiolab 8000A. I always wanted the Audiolab, now I have one, I wish I had never bought the Cyrus. I'm looking for a CD player for my system so any advice/pointers would be much appreciated. Dave |
#5 |
Hi Dave,
Yes, I'm aware of the thinking behind the shape of the sixes cabinets. The unusual shape of the sixes was to reduce standing waves and to allow differently sized, smaller panels to be used. Different sized panels have different resonant frequencies and smaller panels have a higher resonant frequency. This means that the resonant frequencies are spread out rather than reinofrcing each other and also that the higher resonance is affected less by the strong low frequency energy. I also remember Tannoy mentioning that angled sides reduced diffraction but I don't really know enough to believe that it makes much difference. They were also implementing their differential Material Technology (D.M.T.) in the sixes so maybe more glue joints was another side benefit in their view? The lack of bass I had, over two years ago now, just made me wonder if they were 'voiced' to sound better in close proximity to corners or failing that, close to a back wall. I mentioned this because some of the older 'classic' Tannoys that were a similar shape and designed specifically for corner placement. Interestingly, I moved them closer to a back wall with good bass results but not so great imaging. Some time after this old thread, I made my own active baffle step filter or 'bass boost'. The bass was awesome but adding something else into the signal chain affected the Tannoy magic. Oh well, It was a very interesting experiment. What happenned next? I'm actually very happy with the bass at the moment. Some new/higher capacitance caps in the Low frequency/mid-range amplifier give it 'solid' bass and attenuating the HF driver helped resolve the issue of balance. I think a lot of the problem is based in psycho-acoustics and the rather forward nature of the compression driver. Best wishes, Martin.
Martin + + |
#6 |
The room they are played in makes a huge difference! I've moved my old MK1's around a bit and the best spot was in front of (about 30cm away) a brick wall on wooden floors in a wharehouse I lived in.... Pioneer A400 powered them Ok.
Cheers, Nick |
#7 |
I'm looking at the 6's and search's keep bringing me back here, to posts about inadequate or missplaced bass. So sorry for the old post bump but i thought i should comment.
The cabs used are very poor. Each of the boards seem to of been held in place while someone wrapped the cabs in fablon and called it done. I looked at lots when i bought some 603(maybe5)se's. Every single demo set of 6s were split and it took a few shops/boxes to find some that were not. Soon after which these also split. There just not a good cab, so i feel confident that in all case's of poor bass you need to glue them up. There was no sign of this being done from new. I'm actually looking for tatty one's as i won't want to use the cabs. Im yet to see a set that are not split. Check ebay for confirmation. Your cabs will most certainly want a smear of epoxy up the inside. For which i turn to pillar cement. Used to stick short galvo pillars to a concrete floor, upon which large block floor panels rest. It's a cheap way of getting lots of epoxy. |
| tannoy 615 mk 11 | tricia | Multi-Way | 0 | 26th July 2009 10:12 PM |
| Tannoy 609 compared with Tannoy 615 | photomusicfreak | Multi-Way | 4 | 27th November 2008 10:27 PM |
| Tannoy S10 | noyan | Multi-Way | 1 | 10th January 2008 04:04 PM |
| Tannoy TS8 | inrank | Subwoofers | 0 | 12th May 2006 01:34 PM |
| Tannoy i12 set of three | RHosch | Swap Meet | 4 | 17th May 2004 07:25 PM |
| Page generated in 0.12552 seconds (82.57% PHP - 17.43% MySQL) with 10 queries |
