Old 4th November 2006, 02:50 PM   #1
JohnG is offline JohnG  United States
Default Panasonic SA-XR55 bi-amp question
Perhaps someone knows the answer to my question. I have searched long and hard to no avail.
I currently have a pair of Magnepan MMGs, and a pair of Dayton RS315HF woofers. I would like to put the woofers in sealed boxes, which would serve as stands for the Maggies.
The Panasonic SA-XR55 receiver has bi-amp capability, so I thought this would work well with the setup. I would use a passive crossover at about 150-200Hz, and I do not have a problem with the large crossover components that would be required.
However, I do have a different problem which is that the woofer has considerably higher sensitivity than the Maggies. However, looking at the manual for the Panasonic SA-XR55 receiver (page 21), I see what looks like a HF/LF balance setting, which I think would allow me to see the relative output of the HF and LF channels.
Can anyone confirm that this is how it works, and does anyone have an idea of the adjustment range?
As an aside, the manual also shows that you can adjust the HF/LF relative delay.
John
Old 4th November 2006, 04:48 PM   #2
KinK is offline KinK  Canada
I've an XR55 and played with it quite a bit in bi-amp mode with my M3si's. The HF/LF output settings are not a large range, in my seat-of-the-pants estimation the boost at the extreme is about +5dB, maybe less, I'm pretty sure not more. I have no way to measure this and could not, like youself, find any specification for this anywhere. So this advise is worth what you're paying for it.
Kevin
Old 6th November 2006, 11:08 PM   #3
Thanks for the info. At least the functionality is confirmed.
John
Panasonic SA-XR55 multiplying the channels DAMIC Class D 1 1st June 2009 10:12 AM
FS - Class D Panasonic SA XR55 HT Receiver t-head Swap Meet 2 29th December 2008 12:12 AM
Issues connecting i2s from Envy controller to TAS5076 (Panasonic XR55) pawelp Digital Source 8 4th May 2008 07:22 PM
Direct i2s connection from soundcard to Panasonic XR55 pawelp Class D 12 23rd September 2007 07:19 PM
panny sa-xr55 jkeny Class D 5 27th September 2005 04:54 AM
Page generated in 0.06053 seconds (80.49% PHP - 19.51% MySQL) with 10 queries
