Old 4th November 2006, 01:01 AM   #1
Eton is offline Eton  United States
Default Baffle Step Response in WWTM ?
Do I still need a Baffle Step Response circuit if I’m using 2 woofers in parallel which increases the SPL by 6 B in a WWTM configuration?
Old 4th November 2006, 04:59 AM   #2
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
3dB bsc for stereo is o.k since its not a bass helper woofer situation. You just create a 6dB stronger woofer when in parallel, still with same step contour.
Old 4th November 2006, 10:36 AM   #3
BobEllis's Avatar
It depends on the baffle width and crossover point. If you are crossing at the appropriate point and the woofers' net response is 6 dB higher than the mids, you can skip a BSC circuit. Check out The Edge from www.tolvan.com for an excellent, free baffle step simulator
Old 4th November 2006, 11:01 PM   #4
Thanks for advice and link.
Since the baffle is 10.5 inches long that translates to frequency of 431 which is where I intend to cross over the midrange. So I guess I will not need the BSC circuit.
Old 5th November 2006, 10:11 AM   #5
Salas's Avatar
Don't employ 6 dB full bsc by any method. Only 3. In stereo the 2 speakers are gonna correlate up to the hundreds region due to their relatively long inter-distance related wavelength. Your in room power response (in other words what you gonna finally perceive) is going to be bass heavy with 6dB of bsc.
Old 5th November 2006, 05:36 PM   #6
bigwill is offline bigwill  United Kingdom
Put one of the woofers on the back then you won't need any
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
About power amp step response etc. :-) PMA Solid State 21 23rd February 2009 08:45 PM
baffle Step rgrayton Full Range 33 4th December 2004 11:16 PM
Baffle Step + Sub Aural Dan Multi-Way 7 9th October 2004 08:23 PM
baffle step help. AudioGeek Multi-Way 3 10th February 2004 11:02 AM
Page generated in 0.09044 seconds (76.24% PHP - 23.76% MySQL) with 10 queries
