Please follow the link:
http://www.partsexpress.com/projects...la/nebula.html Note the graph "Software Modelled Frequency Response". What I see is that the phase is reversed @ ~49Hz from the ported box tuning frequency. Then @ ~1.8kHz the phase reverses again @ the XO point. Is this correct? I ask because it looks like the tweeter and woofer cross @ ~2.1kHz. But I'm thinking this may have something to do with the natural roll-off of the drivers themselves??? The reason I ask, is that I want to make this speaker except with an active XO. So naturally I want to know what XO frequency I should shoot for on my 24dB/octave Linkwitz-Riley XO. TIA. |
#2 |
When you use the 4th order LR xo, that will put your drivers phase 360 degrees out, so it's pretty normal to have some big phase differences at the xo point.
You need to pay attention to the baffle step compensation - most 'off the shelf' active xo's don't do this. You'd need to measure the boxes to find out what you need to do. Looking at the bottom 'real' response graph I'd be worried about the big suckout in the 'kick' region - roughly 70Hz - 180Hz. Hopefully thats a room problem, otherwise these speakers would sound pretty weak. Rob. If your serious about doing the active xo check out Linkwitz' site for some great info: http://www.linkwitzlab.com/ |
#3 |
It look like a very typical phase response.
Hear the real thing! |
| Determining Xover Point with Waveguide | Horizons | Multi-Way | 14 | 19th November 2008 04:43 PM |
| Wire Wrap connections for point to point | mashaffer | Tubes / Valves | 10 | 7th July 2007 01:11 PM |
| Benifits of point to point wiring for digital circuit? | MGH | Digital Source | 15 | 14th September 2006 10:17 PM |
| Anyone use magnet wire for point to point wiring projects? | Hybrid fourdoor | Parts | 10 | 2nd February 2004 08:11 AM |
| Audio Note's Kit One done in point-to-point wiring | Wram | Tubes / Valves | 18 | 29th April 2003 10:59 PM |
| Page generated in 0.08931 seconds (75.09% PHP - 24.91% MySQL) with 10 queries |
