Has anyone else seen this issue with Martin's TL speaker mathcad worksheets :-
Assuming calculation is set to automatic in mathcad, if I scroll down until a plot is visible, it starts calculating. But, it doesn't just calculate the visible plots, it calculates all of them, even though I haven't scrolled down further. With Martin's latest sheets (with the Part 2 and 3 sections on BSC, etc), this can take several minutes. So, if you just want to tweak a parameter, it ends up being a very slow and tedius process. Martin says this shouldn't happen, but I've tried it on two different machines with the same result. Is there a hidden setting in mathcad I need to adjust ? I'm using Mathcad 2000 Pro. (Martin has kindly supplied an earlier version of his MLTQWT sheet without Parts 2 & 3, which is much quicker). TIA Chris. |
#2 |
...truth seeker...
Hi Chris,
I've had similar experience. If I do not scroll into Part 2 it does not auto calc. If I do scroll into Part 2 both it and Part 3 calculate. I find if I keep my cursor in the margin of the page I can get to the response graph I'm most interested in before the calc routine begins. I suspect the calculations are linked and supportive of one another and that "turning them off" would be difficult.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#3 |
Hi Ed,
I don't see this. Even if I position the cursor in Part 1, it calculates the whole worksheet. I tried scrolling down so that the last plot in Part 1 was visible (but not Part 2). Pressing '=' then starts the calculation, and I can see when it gets to the last plot of Part 1. But it doesn't stop, it just carries on with the very long Parts 2 & 3. Martin is adamant that this doesn't happen on his installation, but I have tried two completely separate instals on different machines and get the same result. Chris. |
#4 |
Sorted !
The problem is a bug in Mathcad 2000 Pro. Tried Mathcad 8 Pro instead, and that works fine. |
| mathcad worksheets | brsanko | Full Range | 0 | 15th March 2009 07:53 PM |
| New version of Martin King's MathCad Worksheets is coming soon! | Scottmoose | Full Range | 344 | 7th January 2007 11:33 PM |
| New versions of Martin King's MathCad worksheets | Scottmoose | Multi-Way | 0 | 14th December 2005 10:05 PM |
| Page generated in 0.08795 seconds (70.52% PHP - 29.48% MySQL) with 10 queries |
