I have an old tube amp. Are this speakers suited for an tube amp or should I buy something else?
#2 |
16 ohm ? depends on if your valve amplifier is 8 or 15 ohm. If its 8 you could use two, or use one and have a 16 ohm extension cab. |
#3 |
my amp has both outs, 8 and 15. The thing is that a friend told me that trere is a big diference between speakers for tranzistor amp and speakers for tube amp. Are G12M70 good model to use with an tube amp? I want to buy 2 of them 8 ohm
#4 |
Hi, used in pairs for a Marshall 2205 50W valve head,
#5 |
and...? How do they sound?
Are they near to the G12T75 that are used usualy in marshall cabs? |
| celestion 66 needs Mid-range | Mr_White | Multi-Way | 865 | 27th May 2012 09:04 AM |
| Celestion SL6si | rubidium7 | Multi-Way | 7 | 17th November 2011 12:50 PM |
| Celestion MD-500 and MF-500 | peterdav | Multi-Way | 1 | 9th December 2010 09:29 AM |
| celestion cs-7 | marijan | Multi-Way | 1 | 23rd December 2002 04:43 PM |
| Page generated in 0.07382 seconds (66.81% PHP - 33.19% MySQL) with 10 queries |
