Old 22nd December 2002, 09:40 PM   #1
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
Question Triangle-pyramid shaped speakers
Hello, I'm a true newbie to DIY speakers, and I did a search for the term "Pyramid." If you can direct me to where this has been discussed before, I'd much appreciate it.
I inherited a pair of triangle pyramid cabinets that were designed for a 10" woofer and a 3 1/2" driver for high frequencies. In the course of history, they were modified to hold two 5 1/2" drivers. The drivers were destroyed by a little brother's ignorant thumb (Augh!). There were no other electronics inside.
I'll give you the measurements, then describe what I'd like to do.
It's built with 3/4" presswood of some sort.
  • inside height from middle bottom to top peak is 14"
  • the length of each joint is 16"
  • According to V=1/3Bh, that comes to roughly 520 cu. in. right?
  • 520 cu. in. comes to .3 cu. ft. or 8.5 liters
I went to Parts Express to search for parts (go figure) which might make these speakers into a nice 2-way system for about $200 or so. I'd like to replace the front-panel with a substantial Vifa driver (P21WO-20) that has decent frequency response so that with a decent tweeter (D27TG-05) the system might cover the whole range without a big dip somewhere in the midrange.
Firstly, is that a decent proposal? That's an 8" woofer in an enclosed configuration. I could go to 6 1/2", but I want that bottom end if at all possible.
Secondly, I haven't got a clue as to crossover configuration. I can solder and I understand impedance and capacitance, etc., but can I just buy one designed to crossover at 2500 or 3000 Hz? That would make my life much easier.
BTW, I'd like to see a discussion of the benefits of an equilateral pyramid as far as the whole "parallel surfaces" thing is concerned. No ports or anything, either. Hmm...
Thanks!
Old 22nd December 2002, 09:46 PM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Can you post a pic of some how. ?
Old 22nd December 2002, 09:59 PM   #3
kneadle's Avatar
Will this work?
Old 22nd December 2002, 10:03 PM   #4
kneadle's Avatar
You can kinda make out where the 3 1/2" driver went. The 10" filled up most of the remaining panel.
Old 23rd December 2002, 12:30 AM   #5
frugal-phile(tm)
planet10's Avatar
Actually that looks like a tetrahedron... beauty.
You might actually get more bass from a 6" driver in such a small box. Personally i like an even smaller midbass (and add a sub later). A Vifa P13 perhaps.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd December 2002, 12:50 AM   #6
kneadle's Avatar
yes, tetrahedon. That's the shape. I said "triangle" to get that across. I'll do a search for tetrahedon now!
I'd like some more input, though. I'm sure I can learn a lot about why the 6" has better low-end response in this thing.
Old 23rd December 2002, 01:17 AM   #7
Banned
Send a message via MSN to SkinnyBoy
Are there any benifits in using that shape enclosure for ported speaker boxes? I ask cos I am doing woodwork next year and would like to make some speakers... ported, using 6inch Response speakers (from jaycar) and am not sure if the teacher will allow me to make just simple rectangular prism boxes..
ALSO!!!!! while I am here... how do the ReSponse 6inches compair to the Vifa P17WJs (sorry, couldn't find a link to info on them.. )
Old 23rd December 2002, 01:26 AM   #8
frugal-phile(tm)
planet10's Avatar
This box has no parallel sides. It should be a decided improvement over a rectangular box.
dave
Old 23rd December 2002, 01:33 AM   #9
frugal-phile(tm)
planet10's Avatar
An 8 generally will need a bigger box than a 6. If you put a speaker in too small a box you end up with a high Q -- a big bump in the response which doesn't sound good. The smaller driver, with its requirement for a smaller box could well have a more realistic Q.
dave
Old 23rd December 2002, 02:18 AM   #10
kneadle's Avatar
Hmm. I tried all the calculating I could understand with pebox, and it seemed like the 8" I picked out could fit in a .3 cu. ft. box.
Maybe Im ignorant, though. That's why I'm here.
Oops! Upon double checking, I see that I was wrong! The 6 1/2" P17WO-20 (for skinnyboy: http://www.partsexpress.com/pe/showd..._ID=7856&DID=7 )
is actually made for a .28 cu. ft. sealed configuration, the size of my box within 2/100ths.
But that's my next question: Is a tetrahedron actually behaving like a .30 box or like a 1.0 cu. ft. box? Do you get my drift??
Triangle shaped metal music maker? Daveis Planars & Exotics 242 14th June 2011 09:11 PM
looking for sloped/phase aligned/triangle shaped speakers Hybrid fourdoor Multi-Way 3 16th October 2005 10:28 PM
Page generated in 0.11737 seconds (78.56% PHP - 21.44% MySQL) with 11 queries
