Old 1st November 2006, 05:15 AM   #1
Send a message via AIM to Spasticteapot
Default Tapering a transmission line...with styrofoam? Would it work?
I have the woodworking ability of a gerbil. A demented gerbil. On stupid pills.
However, I have a hot wire cutter and quite a bit of foam handy. I'm working on the following speakers:
http://www.t-linespeakers.org/projec...son/index.html
and cutting the 2x4 to the correct taper looks to be a pain in the kiester. Could I dampen the sound while tapering the line by replacing the wood with expanded polystyrene (Bluecor insulation foam), or would this not work?
Old 1st November 2006, 03:53 PM   #2
Anybody?
Old 1st November 2006, 04:00 PM   #3
pinkmouse's Avatar
Got to be worth a try!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st November 2006, 04:20 PM   #4
TerryO is offline TerryO  United States
TerryO's Avatar
Default Re: Tapering a transmission line...with styrofoam? Would it work?
Dear Spaz,
From what I've seen of "Blue insulation foam" it should not only work, but probably work very well. I've always been meaning to get, or build, a hot wire cutter and use it for shaping a speaker cabinet and then glassing over it with cloth and epoxy. If you go for it let us know how it worked.
Good luck on your project.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 1st November 2006, 07:21 PM   #5
Speakerholic
Cal Weldon's Avatar
You mean extruded not expanded don't you? The stuff sometimes called Roofmate or styrofoam SM or even type 4?
It must be because I can't see the expanded (bead board or popcorn) working near as well. Extruded is nice and dense compared with type 1 or type 2 expanded.
And yes it works well provided it is a vented cabinet.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
FS: JX 92S in Transmission line cab t-head Swap Meet 6 8th April 2011 05:29 AM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
Transmission Line for or against? DJ Sense Full Range 5 10th June 2006 08:35 AM
Help with Line Array wiring_Power tapering sqlkev Multi-Way 20 24th July 2004 07:32 AM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Page generated in 0.08900 seconds (74.36% PHP - 25.64% MySQL) with 10 queries
