Old 1st November 2006, 03:15 AM   #1
Default Port front or back??
Where to put Port front or back? Does it make a difference??
Old 7th November 2006, 08:07 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
On the back: Port noise will be less audible. On the other hand, one meust make sure that the speaker is not placed too close to the back wall, or in a bookshelf. For commercial products, the designer rarely knows how the end consumer will place the speaker, so it might be safer to put the port on the front. For DIY speakers, the back side is better IMO.
There also is a slight difference in the response due to the longer pathway from the back, but that difference is usually very small, and it is impossible to say which is better without looking into the details of the given design.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 7th November 2006, 08:51 PM   #3
Thank you Svante,
Since my original Question, I have nearly finished my speakers. A 3 way truncated Pyramid design, and I have placed the Port on the back, I think I did the right thing.
Old 7th November 2006, 09:44 PM   #4
AKN is online now AKN  Sweden
Enjoy good sound
AKN's Avatar
Build a test box and compare....
I prefer front port as I want all sound radiate in one direction and have woofer and port sum close. Low freq is ominidirectional but speakers nevertheless tend to be more dependant of placement to back wall if back ported.
Regarding the drawbacks of front port Svante is right on.
/ Anders
Old 8th November 2006, 10:59 AM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Another benefit with the port on the back is the mids leaking out the port are in the shadow of the box so less will be heard.
No longer DIY active
Rear port and front port barry.childs Multi-Way 10 27th February 2009 09:46 AM
horn speakers- back and front loaded Johnnyd Multi-Way 3 13th February 2007 02:40 PM
Open back front horns mashaffer Multi-Way 3 24th June 2005 04:57 AM
rear port vs front port Jimmy154 Multi-Way 22 6th March 2004 08:38 AM
Page generated in 0.08256 seconds (73.08% PHP - 26.92% MySQL) with 10 queries
