#21 |
First, the way I simulated this. I used a freeware version of Bullock and White's Transmission Line DOS simulator. Playing around with this program some time ago, I found that the program had a provision for an enclosure behind the woofer that is NOT part of the Transmission Line. Experimenting around with this, I discovered some months ago that if you make this enclosure large and the Transmission Line the size of a vent in a bass reflex, it perfectly models a ported box. Well, almost-more about that momentarily. Program is downloadable at Bob White's home page here:
http://www.hal-pc.org/~bwhitejr/ Bullock and White also have a different freeware program, available at the same place, that models closed, vented and drone cone, (passive radiator), boxes all by itself. The program I am using is meant for Transmission Lines. but you can manipulate it to model vented and even closed boxes. The advantage of using the Transmission Line program to model ported boxes is that the Transmission Line program has provision for type of stuffing and amount of it. Ported and Sealed programs generally do not. So we can model a ported box with stuffing in the port by calling the the volume of the enclosure the small enclosure at the top of the line, and calling the port the Transmission Line. It would be useful to download WinISD or any other quick simulator to get the dimensions of the port that tunes the box to a certain length. The Transmission Line Simulator does not have provision to tune by frequency, because it was designed to model Transmission Lines, not ported boxes. A glitch: when you model a box of a certain size with a port of a certain size, the Transmission Line program for some reason shows it as tuning the box half an octave higher than any program, with a response curve to match. Why? Who knows? All I can say is to use Win ISD to model the box you wish, set WinISD to give you a port length that tunes the box half an octave, (.7 of the desired Fb) and transfer that port length and area to the Transmission Line model. The impedance curves of the Transmission Line model confirm that you will have the correct tuning when you use this method!! Smaller glitch: even when you use the above method to get the correct tuning, the Transmission Line model will give you a ported box that is [1]slightly[/i] optimistic. A box that Win ISD will show an F3 of 30 Hz, for instance, will show up here with an F3 of maybe 28 Hz or so. Nothing to get excited about, just bear it in mind. Incidentally, the separate program by Bullock and Whtie meat for modelling closed, vented and drone cone boxes do not have either of these glitches. Go figure. |
#22 |
A word about stuffing. This Bullock and White Transmission Line freeware program allows you to use specify both fiber size and density in the program. Since most speaker buildlers do not have data sheets full of fiber sizes of various densities hanging around the house, Bullock and White happily give us a default stuffing: it is DuPont Hollofil.
Hollofil is a polyester stuffing material that is used extensively in jackets, sleeping bags, pillows and comforters. You can also take comfort in the fact that it is nonallergenic, so you don't have to worry about your speakers making you sneeze. DuPont assures us that Hollofil has has at least 10% more fluffiness than that awful, grotesque unbranded polyester stuffing material that no sleeping bag manufacturer or pillow magnate would let himself be caught dead using. http://www.dupont.com/insulations/pr...llofil808.html Fiber size aside, the Transmission Line freeware modelling program has a nice feature called Packing Density, which tells you how many kilograms of stuffing per square meter the Transmission Line, (the vent, in our case) is stuffed with. That way, you can calculate what percentage of a cubic meter your vent is, and multiply a kilogram by that fraction to find the weight of stuffing your vent requires. Those unfamiliar with the Metric System, (like every man, woman and child between Canada and Mexico), should know that a kilogram is 2.2 pounds, or 35 ounces, and a cubic meter equals 61,000 cubic inches. The default Packing Density is 8 kilograms per meter, which the authors figure is what most Transmission Line builders pack their Lines with. However, I found the simulations work best with only 1 kilogram per cubic meter. This might create problems with packing the vent with a thin enough density. Perhaps only parts of the vent can be packed, and spaces in between left empty, like the manufacturer that Phase Accurate discovered who used an otherwise clear vent with one section full of open cell foam. Perhaps our Transmission Line experts can help us out here. Anyway, I shall compare an imaginary, (but based on a Peerless 10" CSX) woofer in a 2 cubic ft. (56 liter) box tuned to 27 Hz with both stuffed, (at 1 kilogram per cubic meter), and unstuffed port. For cone excursion, I shall compare both to a sealed box with in a large enclosure with an F3 the same as the stuffed port box. |
#23 |
As I understand Pjotr's goals, he wants an enclosure that has
A) A bass rolloff similar to a second order, (12 dB/octave); B) A substantial degree of output from the port (to provide cone excursion relief for the woofer); C) Box size, sensitivity and F3 cutoff roughly comparable to a bass reflex box. The simulations show that, within reason and with certain bass reflex setups, a stuffed port box can provide ALL of these requirements! Basically, the simulations show that by properly stuffing the port, you can move the bass rolloff curve UP one order, (say from fourth to third), by sacrificing about a quarter octave of response at F3. So a speaker with an unstuffed port that has an F3 of 30 Hz and a 24dB/octave rolloff in the first octave under F3 will have, when you lightly stuff the port with 1kilogram per cubic meter of Hollofill, an F3 of 36 Hz and an 18 dB/octave rolloff in the first octave under F3. Clearly then, the smart thing to do is to choose a bass reflex speaker/box combination that has a third order, (18 dB/octave) rolloff to start with. Then, when you move it up an order, (for newbies, 6 dB/octave is an "order"), you have something getting close to a second order, (12 dB/octave) rolloff, at least for the first octave under F3. Such a combo-third order rolloff with unstuffed port-requires a speaker with a Qts of around 0.24. A little lower than average, but these woofers are available. I have also seen where speaker author David Weems raised the Qts of a speaker by putting a resistor in series with it. Page 3 of this thread shows a reprint of part of a book chapter where he did this. article about double chamber speaker enclosure He did not state that you can lower the Qts of a speaker by putting a resistor in parallel with it, but the implication would seem to be there. Of course, the SPL of the speaker will be cut the more you lower the Qts, so if you must use this method, start with as low a Qts woofer as possible. |
#24 |
The imaginary speaker I used has:
Fs = 15 Hz Qts = 0.24 Vas = 224 liters SPL = 86.8 dB @ 1Meter/1Watt The box is 56 liters tuned to 30 Hz. Here are the Thiele-Small listings and screen shot of the Bullock-White Transmission Line Box Modelling Program, version 1.3. Shown is how to model between stuffed and unstuffed ports for the same box. |
#25 |
Here is the frequency response charts for the identical box with both a stuffed line and an unstuffed line.
Unstuffed line in Light Blue. Stuffed Line in Red. Sealed Box with a different woofer and larger enclosure, with a Qtc of 0.7, and a response and F3 identical to the stuffed line in Purple. This is for comparisons with cone excursion. |
#26 |
Impedance chart for stuffed and unstuffed port. Note how the stuffed port moves the resonance frequency down slightly. Remember the speakers and enclosures are identical except for the stuffing in the ports.
The unstuffed port resonance means the box is tuned to around 27 Hz, not 30 Hz as I stated earlier. Note how the stuffed port also has a lower impedance at the high resonance peak. In other words, it is making the speaker act a little more like a closed box. |
#27 |
Hi KelticWizard
Have you tried comparing the B&W model to the Martin J King one, I would be interested to know if it produces comparable results. Your models certainly look interesting, I might have to have a play sometime in the future, if I ever have time!
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#28 |
Here, on the impedance phase, we see that the stuffed port acts very much like the unstuffed port.
The purple line is the closed box with the frequency response identical to the speaker with the stuffed port. Very, very different. Unlike the impedance plot, there is little evidence the stuffed port makes the speaker act more like a closed box at all in this measurement. |
#29 |
Pinkmouse:
I got started on this because I was playing around some months ago with Bullock and White's Transmission Line freeware and discovered that I could transform it into something could model a bass reflex system as well. Never thought it would do me any good until this thread came along. Now that I have started down this path, I really should download Martin King's program and compare, especially since he is a member here. The way I modelled the closed box, even though the Bullock and White freeware have no provision for it, is to A) Punch in Thiele-Small number for a woofer with the SPL of 86.8, a Qts of .5 and an Fs that is one half octave below the stuffed stuffed vent's F3 of 30 Hz. B) Made the box equal to Vas C) Since the software has no provision for a closed box, I just made the Sd of the vent real, real small, and stuffed it fully. This lowered the tuning frequency to smething like 5 Hz and essentially gave the speaker the characteristics of a closed box in the octaves of interest. Anyway, back to the speaker modelling salt mines. Next up: Cone Excursion!! |
#30 |
Here we see the notch in the cone excursion is lessened in the stuffed port box, but it still gives substantial relief to the woofer.
The stuffed port speaker only has to move about half as much as the closed box speaker with identical passband response at 30 Hz, which is F3. The stuffed port box only has to move about 75% as the closed box speaker one half octave above F3-which is 42 Hz. Again: The unstuffed port is in Light Blue The stuffed port is in Red The closed box with frequency response identical, (down to F3) to the stuffed port is in Purple. So here we see some evidence that the stuffed port acts somwhat like a closed box, but still retains most of the characteristics of the bass reflex. |
| Lossy vs lossless compression | alleycat | Digital Source | 4 | 7th June 2008 07:56 AM |
| Intentionally Lossy Box | ch83575 | Multi-Way | 1 | 25th February 2006 08:52 PM |
| Somebody damped that discussion over here | Fred Dieckmann | Everything Else | 17 | 23rd July 2003 11:01 PM |
| curved ports vs. multiple ports | Craig | Multi-Way | 1 | 22nd September 2002 08:30 AM |
| Page generated in 0.15804 seconds (85.18% PHP - 14.82% MySQL) with 11 queries |
