what are WLM DIVA speakers made of?
it would be hard not to use the XO ideas from Eminence, as the driver has it's resonant frequency at 2.5kHz and is usable from about 3.5kHz up. That makes it necessary to cut the driver at 3.5kHz 3rd or 4th order electrical. The cone breaks-up lower than that, so there's not much to do about that with the XO. Just tune it to be in-phase with the driver and have relatively flat response.
Eminence sells kit XO-s for the coax set that cut at 3.5kHz 2nd orger woofer and 3rd order driver.
