Alright check this out for an idea:
I have a pair of original KLH model 6's, with the epoxied woofer - crossover for the tweeter is no longer passing signal, and anyone who's seen these old 6's knows you can't get into the box without a dremel or circular saw. What I propose to do is this: Repurpose these as 'bassboxes' for the bottom end of any number of speaker projects. I *think* I should wire in series an additional coil to the + input, which will drop the low-pass crossover point to 200 - 250 Hz so I may use the Model 6 as a bassbox. Did the 6 have a coil as a lowpass, or did the woofer roll off naturally on the top end ? If there is a coil anyone know it's value so I can do the math for the additional coil ? I have a whole mess of the KLH 4" fullrange drivers that I'm itching to do a OB line array with just for kicks thanks, Mark |
| Some kinda XSoZ | Fuling | Pass Labs | 9 | 27th June 2004 07:17 PM |
| ML TQWT 2-way? (kinda long) | Sherman | Multi-Way | 5 | 2nd March 2004 05:03 PM |
| kinda off topic but i figured i would ask ya'll | kaukasion | Solid State | 10 | 22nd January 2004 04:31 PM |
| What kinda Batterys are these. | jleaman | Parts | 6 | 13th March 2003 02:32 PM |
| Spice Model question | Ian Macmillan | Solid State | 3 | 5th July 2002 09:36 AM |
| Page generated in 0.06726 seconds (70.55% PHP - 29.45% MySQL) with 10 queries |
