what happens when you increase the port length by 2 feet, note that the extra two feet would be outside the box and would not affect internal volume of the enclosure
na |
#2 |
should work no real issues.
#3 |
A vent (tube) for a bass reflex designn speaker can extend from the speaker, if you wish, vs. being internal. But, for the speaker to operate properly, it would need to be the same dimenstion and lenght as the internal vent.
If you extened an existing vent for two feet, you would unalign the speaker's bass response presuming the original vent was the proper lenght. At that lenght, you might get a lot of chuffing (air passing thru the vent) noises as well. Hey, I say your line array desing some time ago. How do you like the final product? Looks great. |
#4 |
The do a lot amazingly well. The are clean, articulate, very very dynamic (pow!), incredible pop in the upper bass. The image pretty well too. But the best quality is the soundstage, huge!
Downsides, a couple. The tweeters are not quite clean enough, especially the low end. This becomes audible in certain music that has a lot of emphasis in the crossover region. They are very sweet sounding though. No complaints about the mid-bass and midrange, really about the best I have heard. Actually I think Darren, formerly of Parts express, probably stumbled on the best approach on the Colossus, use 50" BGs as tweeters crossed over pretty high, with an array of mid-basses, and an active crossover. I wouldn't place the subwoofers in the same towers though. James |
#5 |
If the original vent were already tuned correctly, increasing it by two feet outside the box would increase the air mass in the port to the point that the box would approach an AS (i.e. sealed box).
Cheers |
#6 |
Did it Himself
Yes as above and there also would likely be pipe resonance issues.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
If you do,make it flared.
xxx I should correct my spelling xxx |
#8 |
Did it Himself
There is no absolute need to flare it, unless the diameter is on the small side.
| port length | jwhit67 | Multi-Way | 1 | 6th March 2008 12:29 PM |
| Help with port length please | Bobhof | Multi-Way | 3 | 2nd May 2006 06:32 PM |
| port length | busterno1 | Multi-Way | 5 | 27th October 2003 08:05 PM |
| port length | dave k | Multi-Way | 13 | 13th July 2003 02:32 PM |
| Page generated in 0.09099 seconds (77.93% PHP - 22.07% MySQL) with 10 queries |
