newbie warning...
Is there a way to boost this frequency range by modding a passive 2 way crossover ?
na |
#2 |
Not simply. What is your kit and what are you trying to achieve?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
na |
#4 |
Speakerholic
Link doesn't work for me.
#5 |
me too... hehehe
there... now its fixed
na |
#6 |
Hi gguy,
I think your Zobel, 2 Ohms and 12uf is missplaced and should instead be mounted over the driver + an - terminal. B |
#7 |
Hi qguy,
I must explain why I first thought the vertical branch of your filter is a misplaced Zobel. Looking at your R,C, L branch, I found a low Q and a center frequency of 1125 Hz that is very close and is strongly interacting with the other components, so I tested with two different loads to se what happened with the amplitude and the phase. Then I moved the 2-Ohm resistor and the capacitor and placed the component as a Zobel. For both loads the plots look much better, but I could be mistaken and your filter is in reality a filter with a slope about 4.5 dB/octave and not a close to 18 dB/octave as it looks like? Take a look at my plots : B |
#8 |
pic2
#9 |
bjorno,
Perhaps the filter response is what the driver actually needs. We don't have info on what the xo is driving... for example, it may be a way to extend the frequency response of the LF unit just a bit so that the HF driver can be crossed just a bit higher in frequency... qguy, I've seen KEF use a coupling capacitor into the LF unit to "hump" the response just a tad. The coupling capacitor also reduces extreme LF response so that boosting (via bass control on the amp) allows for a bit more subjective 'oomph' without bottoming out the LF driver... Cheers |
#10 |
Did it Himself
If this band is below the vent tuning frequency, forget it.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| Boosting 25-30 hz | qguy | Subwoofers | 2 | 13th January 2007 02:10 AM |
| Signal boosting | spots25 | Digital Source | 3 | 6th January 2006 01:18 PM |
| Boosting wireless home phone range/antenna ->5.8ghz | JinMTVT | Everything Else | 5 | 22nd October 2005 02:56 PM |
| Cost-effective bass extension from 65Hz | Nuuk | Subwoofers | 36 | 6th February 2004 08:05 PM |
| boosting a boost.. | ChesterFuzzin' | Multi-Way | 1 | 22nd August 2002 08:20 AM |
| Page generated in 0.11106 seconds (78.53% PHP - 21.47% MySQL) with 11 queries |
