#11 |
Hi Curmudgeon,
They didn't have any high, highs either. They just sounded bad. I recall they had a pair of ports and I think a pair of drivers in the rear. Just all the same drivers, no tweeters. Some people love 'em though. -Chris |
#12 |
Speakerholic
No XO. 8 drivers to the wall, one toward you.
All 1 ohm drivers wired in series. Nasty electronics to make 'em work. Cool looking box and groovy stand. How could they not sell? |
#13 |
Hi All,
First of all, thank you for your responses. So I guess this is doable. I do not have drivers at hand currently, but was thinking of this type of an implementation. I am not particular about the low freq (will build a separate subwoofer). If I have drivers 8ohm (or even 4 ohm), and capable of handling 10W output, can I build a system with say 6 of them in series (or parallel) and safely assume this will be capable of handling 60W output? Thanks Din
Regards, Din |
#14 |
Speakerholic
Yes it is doable.
We need more info before we can help. What drivers are you considering? |
#15 |
6 - 8 Ohm speakers: put pairs in series and parallel the 3 "16" Ohm pairs and get 5.3 Ohms - nominal.
6 - 4 Ohm speakers: put 3 in series and put the 2 "12 Ohm" speakers in parallel - get nominal 6 Ohm. Usually ok for most decent amps. Mount speakers as close together as possible to minimize high frequency comb filtering. For best image and sound stage - I would do vertical stack of 6. Don't expect good bass or treble. If you use 9 a la Bose 901, then it is a bit more difficult if you don't have 0.9 Ohm drivers - because of the need to use equal power to all 9 drivers. In any case trying to do a Bose is pointless in my opinion. 901s are not good. This is what I categorically think about "cloning" efforts - Check out this link: http://www.youtube.com/watch?v=tQ2MG...elated&search= |
#16 |
Thanks for you inputs, psych&sound .
I had a look at Bose 901. No I am not planning a "clone" or anything similar to Bose 901. BTW, real nice video in that link, although I don't remember seeing such an ad on the media here. Regards Din
Regards, Din |
| PSU Reservoir Capacitors (Single large vs Multiple small) | Deofol | Solid State | 15 | 13th March 2009 05:03 AM |
| Sub: 1 large or 2 small drivers ? | Bigun | Subwoofers | 52 | 21st February 2009 10:46 PM |
| large v small drivers | marec | Full Range | 15 | 23rd January 2008 08:49 PM |
| Large Driver or Multiple Small Drivers ??? | emailtim | Subwoofers | 8 | 25th March 2006 10:02 PM |
| tradeoffs in small vs. large drivers | jdybnis | Subwoofers | 6 | 10th November 2004 12:24 AM |
| Page generated in 0.09087 seconds (76.55% PHP - 23.45% MySQL) with 10 queries |
