newbie warning...
I made notch filter for the woofer with 22 uF capacitor, 1 mH inductor and 15 ohm resistor. This tames the 1000 hz peak of my 2 ways What would the effect if I reduce / increase the resistor value ? Reduce / increase the capacitor values ? I would appreciate responses such as "the mids would be increased" or the notch would move from 1000 hz to 800 hz"
na |
#2 |
You know how a notch filter works?
The inductor "shorts" low freqs, the capacitor shorts the high freq. as they are in series, only the range between the two "cutoff-frequencies" is shorted. the resistor determines how strong the shortage is. larger resistor, less shortage, more mids (flatter dip). larger capacitor, lower frequency. larger inductor, lower frequency. to experiment you should take a response graph with each modification. |
#3 |
Use something like Tina-Ti (free) to answer your own question. http://focus.ti.com/docs/toolsw/fold...t/tina-ti.html (to get passive circuits to work just add an unconnected op-amp) |
#4 | |
Now I do !!!
This is very much appreciated, I think this is the best response that I got ever from the internet... Quote:
na |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| notch filter help | omni | Multi-Way | 14 | 23rd July 2007 01:11 AM |
| Can Zaphs notch filter be used without the BSC filter? | GuyPanico | Full Range | 0 | 21st July 2007 01:27 AM |
| Do I Need A Notch Filter? | noodle_snacks | Multi-Way | 13 | 31st October 2005 01:35 PM |
| Help with notch filter | nobody special | Multi-Way | 1 | 11th June 2003 02:06 PM |
| Page generated in 0.07676 seconds (78.00% PHP - 22.00% MySQL) with 10 queries |
