Old 25th October 2006, 01:42 PM   #1
percy is offline percy  United States
Default simplest way to suppress resonance peak ?
I have this little 3" driver that has a bad reasonance peak. Sounds like a halloween horror toy (atleast to my ears).
And I think the way it sounds, its this resonance peak that is causing it. If somehow I smooth that out it could sound much better.
Replacing the driver is difficult because of tight space constraints where it is located, but still while I try to find a suitable replacement is there anything I could do to snub/suppress that resonance peak ? I can't use anything with a big honking inductor or capacitor because there is simply no space in there.
I have been tossing around the idea of this "Twin-T RC notch filter". Would that be a good idea ? I am willing to compromise some sensitivity.
Old 25th October 2006, 03:50 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi percy,
You need a circuit that lowers the Q at about 420 Hz 12-13 dB and is adjustable in both Q value and frequency.
A buffered bootstrapped Variable Q Twin T active filter should do the proper job.
Replace the potentiometers with resistors after you’ve found the correct settings.
If you need to adjust the signal level, use the input buffer to form a voltage gain stage.
http://www.geofex.com/Article_Folder...iable_Q_twin_t
B
Old 25th October 2006, 04:29 PM   #3
thanks! its good to know its worth trying.
btw, in case you guys are wondering that the resonance peak is not the only problem with this driver - its not exactly a high fidelity application. Its a shortwave/communications receiver, so...
Peak decibel at resonance sparkless Multi-Way 4 18th July 2009 12:27 AM
200V peak to peak @25MHz ketan Parts 1 8th June 2008 03:21 AM
How to suppress spikes on power supply kmt Parts 1 14th February 2004 12:50 PM
Ultra linear g2-anode suppress richwalters Tubes / Valves 3 30th November 2003 05:49 PM
metal cone resonances, what direction, how to suppress? capslock Multi-Way 24 19th November 2003 09:25 PM
Page generated in 0.07347 seconds (76.58% PHP - 23.42% MySQL) with 11 queries
