Im looking for a (transperent) solution to protect the tweeter when using software based crossovers other than using a cap on the tweeter. I heard it done with relay but wouldnt think a relay is quick enough? Perhaps a solid state relay?
#2 | |
What type of amp are you using ? Regards Charles |
#3 |
Charles,
Aksa 100W Nirvana Plus. Thanks for the tip on the solid state relay's. Might have to test a normal relay on some real cheap low power tweeters. If it works consistantly I spose its safe to assume that a higher power handling tweeter will survive. Anyone using tweeter protection? Do tell..... |
#4 |
Light bulb?
Take the Speaker Voltage Test! |
#5 |
non polar capacitor
regards Andrew T. |
#6 | |
Regards Charles |
#7 |
I have used zener diodes. Two 9.1 volt wrapped and soldered in series with the color bands on the zeners oriented together, then soldered across the tweeter terminals.......respectfully......Omni
| tweeter protection in an active speaker | Cousin Billy | Multi-Way | 12 | 23rd April 2009 02:03 AM |
| Tweeter protection gizmo for active XO? | JoeM | Solid State | 5 | 31st March 2009 08:18 AM |
| Multichannel software digital crossovers? | EchiDna | Digital Source | 6 | 26th May 2004 09:15 AM |
| Tweeter protection Cap | static | Multi-Way | 13 | 14th January 2004 11:52 PM |
| Page generated in 0.11101 seconds (77.08% PHP - 22.92% MySQL) with 10 queries |
