"egg crate" Foam  vs wool felt
Old 25th October 2006, 03:58 AM   #1
qguy is offline qguy  Canada
Send a message via AIM to qguy Send a message via MSN to qguy Send a message via Yahoo to qguy
Default "egg crate" Foam vs wool felt
Which is a better material to line the insides of the enclosure in a 2 way ported system?
What is the general rule with regards to damping.. do I cover everything up
na
Old 25th October 2006, 06:48 PM   #2
JDDCo is offline JDDCo  United States
JDDCo's Avatar
If It's A Ported Box I Would Use Foam
Sealed Use Wool Or Poly Fill
Old 25th October 2006, 08:40 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Wool felt has worked very well for me in TQWT and horns.
Even seen it used to good effect in Onken bass boxes. It ain't cheap, tho. Unless you can find the under carpet stuff.
Take the Speaker Voltage Test!
"egg crate" Foam  vs wool feltHide this!Advertise here!
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
Help finding 1/2 inch wool felt ? bigaudioscotto Full Range 11 23rd January 2009 12:02 PM
Any experience here with thin wool felt? david yost Planars & Exotics 9 31st October 2008 05:03 AM
crate vintage "club 50" schematics needed cbriere Instruments and Amps 2 14th November 2007 06:39 PM
WTB: FELT F13 Grey - 1/4" to 3/4" Thick - Like on Duntech/Dunlavy Speakers' Baffle dtm1962 Swap Meet 0 21st October 2006 04:18 AM
