hi everybody. do you have any center channel speaker designs for a teen with a budget of about 200 dollars not including cabinet and fill?
#2 |
#3 |
Speakerholic
What do you have for L & R fronts?
#4 |
i ascend 170s as my fronties.
#5 |
Speakerholic
How about one of these:
http://www.partsexpress.com/pe/pshow...number=264-804 with one of these: http://www.partsexpress.com/pe/showd...number=296-165 |
#6 |
http://www.soundstage.com/revequip/a...ics_cbm170.htm
If its these perhaps one of these : http://www.zaphaudio.com/audio-speaker19.html |
#7 |
you might be able to find a 10inch or 12inch Tannoy dual concentric for that kind of money. Not the modern plastic coned type. Go look for a paper coned bass/pepper pot tweeter model. Voice is very intelligible and high sensitivity requires only moderate power. The DC principle keeps point source at centre and this allows a wide spread of coherent signal to the audience (you and the girlfriend do have some space between you!).
regards Andrew T. |
#8 |
ha
#9 |
not being facetious here understand these aught to come in around or under your budget TC [PS] l intend to build one using a pr of no-name shielded drivers from a korean mfctr l rekon it should work out well with a simple series x/over using a shielded tonigen soft dome tweeter l have lying around gathering dust
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#10 |
l tried to edit to insert the link l wuz talking about but the admin/ or site woodnt lemmy so here it ishttp:// http://www.partsexpress.com/projects...denclosure.jpg
| 3-Way Center Channel Crossover Design | Ben_Tech | Multi-Way | 0 | 2nd January 2008 02:23 PM |
| OB Center channel design | arc2v | Multi-Way | 2 | 11th May 2007 07:30 AM |
| Center channel speaker | LEESTER | Car Audio | 0 | 9th April 2007 08:18 PM |
| Is there any easy way to design a center channel that will match my Polk mains? | mikejz84 | Multi-Way | 6 | 18th July 2003 12:03 AM |
| need center channel design | supes | Multi-Way | 14 | 25th February 2003 11:22 AM |
| Page generated in 0.16848 seconds (58.16% PHP - 41.84% MySQL) with 10 queries |
