Hi everybody
I'm oppressed with a problem connected to my job: I need to have a speaker with the most efficiency I can obtain.I've thought about a woofer of this type http://www.ciare.com/pdf/catalogo/PW328.pdf with a 98dB ! But I need more dB so I thounght about a horn loading. I don't need fidelty but only dB (and if it's possible, a bit of portability). I need only a band between 60Hz-70Hz and 5Khz. But the problem is that I haven't never done a horn loading. How could I do it in a simple way to obtain the best efficiency ? As I saw I don't need particular aligments. Thanks in anticipation ! Bye |
#2 |
up please
#3 |
Did you mean 60Hz to 5KHz?
Anyway, you can download hornresp and try it out. http://www.users.bigpond.com/dmcbean/ |
#4 |
Horns get big fast. I doubt you'll get the whole bandwidth from 1 speaker.
Have a search for the punisher horns - they'll get down to the 60Hz figure, and a pair is quite small and portable. Add a midhorn 300 up it could be possible. Rob. |
| Two drivers loading the same horn. | Tyimo | Full Range | 23 | 20th February 2009 04:19 PM |
| Horn loading a built sub | qguy | Subwoofers | 3 | 25th October 2008 11:32 AM |
| horn-loading: 100% efficiency ?! | e-side | Multi-Way | 54 | 1st August 2006 03:42 PM |
| Horn-loading Ribbon Tweeter? | mefistofelez | Multi-Way | 17 | 9th November 2004 08:58 PM |
| Page generated in 0.07206 seconds (71.88% PHP - 28.12% MySQL) with 10 queries |
