Here is a schematic of my Merlin VSM-m's crossover. Please comment on any upgrades I can make.
The soldering of the crossover parts is very poor, and there isn't any mechanical contact for the components, only solder. I noticed that some of the strands on the caps leads were cut making a smaller gage wire, I assume durring stripping. The large 2.25mh inductor is connected to the caps and woofer wire lead via a solder joint.
I am not looking to change the values of crossover points, just the quality of components. IMHO I think the Caddok resistors and the Hovland caps are good, but the woofer inductor, I would like to upgrade. Please comment.
No comments on upgrades of components? When I post questions in the digital forum, I get comments.
I built North Creek Rhythm speakers years ago, have a slew of Dynaudio drivers and a electrostatic double impact kit that I did not finish yet. I designed a few small first order crossovers and boxes for the dynaudio drivers and decided to purchase a used set of Merlins to play with. I took apart the Merlin VSM-m to do some updates, post the info here for help and get no advise. Maybe nobody knows.
On the digital forum, some are designing their own dacs and some are updating consumer or retail versions. I assumed that purchasing a pair of used speakers, for much less then new, and updating the small parts count crossovers would be normal practice on the loudspeaker forum too.
One mans upgrade is another mans waste of money.
Hovland 16ga inductors doesn't sound too shabby, but what is
a 0.8R resistor doing in series with a 16ga treble inductor ?
Could change this to a 1R air cored inductor, delete the resistor.
Bass inductor, want to go lower DCR or go air-cored ?
/sreten.
/sreten.
Thank you sreten,
I don't know why the .80ohm resistor is there, maybe to try to pull down the tweeter some more. Are you saying I should replace the inductor and resistor with an inductor with the same value as the current, but find an air cored version that has .8ohms more resistance?
I want to change the bass laminated core inductor to air cored. My thought was, if I replaced the current 2.25mh inductor with a North Creek 12ga air cored inductor the DCR will be very close. I would then be able to make the leads on the new inductor long enough to connect the input terminal and the speaker without any other cabling and eliminate an extra solder joint too. I would, of course, scrape the lead after the new inductor to tie in the caps.
I don't like the idea of an iron core inductor on the treble circuit. I'd measure the DCR of the original and an air core one and adjust the 0.8 ohm resistor accordingly. I'd keep the iron core inductor in the bass leg, as the lower DCR of the iron will help you on the bass.
But you know what they say about opinions.
So why are you bunched up about the solder connections? I realize it's not ideal, but in the grand scheme of things, I suspect it's pretty far down there on the list of things that matter in your system.
Sheldon
Sheldon
Mechanical connections are always best. Solder is never as good as a good old crimp or nut. If you look at most speaker connections, the ends are crimped, not soldered. I did government work for years, years ago, and they always wanted a good mechanical connection before it was soldered.
The simple fact is if you've got 0.8R in series with an inductor, using
heavy gauge wire is utterly pointless, I suspect the 0.8R is a later
"improvement" and possibly they kept the advertising blurb of
"low loss" inductors so kept the "low loss" treble inductor.
Go air-cored by all means if you think it will be worth it. The treble
inductor should be fairly cheap as you can adjust the series resistor.
The bass inductors ? $60 a pop. But note just because they are
air-cored doesn't mean you don't have iron in the circuit, after
all the voice coil is in an iron magnetic circuit.
The "improved" "SE" version used a lower DCR cored coil than standard.
/sreten.
/sreten.
I would like to know what Merlin did to update from the -M to the -MM?
I did read that Merlin did a change to a lower DCR coil. My guess is they went from a iron core to this laminated core, wich I believe is better, but I think and aire core inductor is better yet.
I agree that the advertising demanded the added resistor in the tweeter circuit. They probably updated the coil to the laminated one and needed to add the resistor because of the newer coils lower DCR.
Kip said:Mechanical connections are always best. Solder is never as good as a good old crimp or nut. If you look at most speaker connections, the ends are crimped, not soldered. I did government work for years, years ago, and they always wanted a good mechanical connection before it was soldered.
Right, in an ideal world, you would have good mechanical contact then soldered. But I'll take poor contact and solder vs. just a crimp with no solder any day. Look at reference transducers like platinum resistance elements for lab use. The spade lugs are ALWAYS soldered. That's an application that the contact resistance can't change.
I have two 6.9mh 12ga North Creek air core inductors that I am not using. North creek will wind them down for me at a little cost. I think the DCR will be the same, but will make sure.
I was always taught that you must first make a good mechanical contact first then apply the solder. Solder in to keep the parts from moving and keep the copper from oxidizing. I am not saying don't solder your connection. My thought is to get a good wrap on the binding post or speaker connector then apply the solder. What I am seeing is the wire touching the contact then solder applied to hold it there. If I remove the solder with a solder wick the wire should not fall off. With the many discussions about the quality of solder plus the higher resistance it has over copper IMHO you would try not to make a connection with it. In every case I realize this may not be possible. Why pay money, maybe not everyone, on expensive cables or what not to hear a solder connection?
Merlin VSM Crossover
In response to inquiries of Merlin VSM crossover schematics, I cloned my SE version in order to build a VSM Center channel speaker, and essentially duplicated the crossover other than using Alpha Core ribbon inductors. I saw a post here of someone who attached a picture of their VSM-M crossover, but it will not load, and am very interested in seeing it if possible! I am new to this forum, and at this point am not allowed to contact other members. Any help would be greatly appreciated! Am including a pic of my DIY center channel, have been fortunate over the last few years to pick up a pair of Esotar D-330D tweeters at a great price, which seems to be the achilles heel on cloning the Merlins!
I have thrown out all my other resistors since finding Kiwame. Easily the best bang for the buck. For the series coils, the bigger the wire size, the better the sound, but they are expensive. Anything below 14 and you will suffer. Hovland caps are great for the money, unless the tweeter is bright.
Can you place the schematic on the site again. I cannot load the image.Here is a schematic of my Merlin VSM-m's crossover. Please comment on any upgrades I can make.
Steve
- Help me update my Merlin crossover please
