Old 23rd October 2006, 09:12 PM   #1
Default Insignia driver replacement
Simply put, what drivers would work well in the Insignia enclosure? I realize this is backwards from what most people would do, in that I am trying to match a driver to an enclosure. However, I don't have access to the tools required to build an ideal enclosure for whatever drivers I select. So the plan is to re-use the Insignia enclosures because they're nice looking and quite cheap. After dampening/strengthening the box as much as possible I want to replace the drivers. I've been looking at the Seas CA15RLYand the Dayton RS150S-4, but I'm open to suggestions. And I was thinking of using a pair of Hi-Vi RT1L tweeters that I have sitting around, mounted on top, not filling the port as others have mentioned. However, both the Seas and the Dayton seem to require a slightly larger enclosure. Any input on this would be very helpful.
The only other option I've seen is the Peerless 830882, which doesn't have quite the same range as the Seas.
Old 26th October 2006, 09:52 PM   #2
bump
Old 27th October 2006, 08:59 AM   #3
http://www.zaphaudio.com/
No idea what cabinets you are talking about and impossible to find on the net.
/sreten.
Old 27th October 2006, 12:48 PM   #4
http://www.zaphaudio.com/Insignia.html
Old 27th October 2006, 06:36 PM   #5
I have a pair of the Insignia speakers as shown on Zaph's site. The stock coaxial drivers have a rather ragged response, even after fully dampening the cabinet and reworking the crossover. So I'm going to replace them and I'm looking for input on which ones to use.
Old 27th October 2006, 06:45 PM   #6
You'll have to search various drivers and their specs to find one that you like and will fit the box. Here is some info that might help. http://www.pesupport.com/cgi-bin/config.pl?read=290717
Help with replacement sub driver Hugh M Subwoofers 1 11th March 2008 01:19 PM
Replacement Driver jdlech Multi-Way 9 19th February 2008 10:54 AM
Insignia rebuild polkymon Multi-Way 15 3rd February 2007 10:49 PM
Replacement driver for old REL Q50 sub smallangryboy Subwoofers 3 9th May 2006 03:37 AM
Kls-9 driver replacement dinamic1 Multi-Way 0 14th March 2002 10:35 AM
Page generated in 0.08008 seconds (73.65% PHP - 26.35% MySQL) with 10 queries
