Old 23rd October 2006, 08:59 AM   #1
VelluPiri is offline VelluPiri  Finland
Default Using MJK´s alignment tables
Is it nesessary to do open end boundary correction every time?
Or only when taper ratio is 1
I am referring MJK´ focal example
Is this same phenomen what is in ported box
(actual port must be shorter than calculated)
Can I use that formula for that?
Is there somebody nothing to do?
Willing to do some math for me?
Want to put D.Murphys CAOW1 to mass loaded TL
Ain´t got those Math Cad models
Harri
Old 23rd October 2006, 12:03 PM   #2
MJK is offline MJK  United States
Yes, the open end correction should be made for tapered, straight, and expanding TLs.
Yes, exactly the same correction.
A few days ago I updated the alignment tables article to add more steps in the example so that it is easier to follow. Hopefuly that will help people who are struggling to put the right parameters into the equations.
Hope that helps,
Old 23rd October 2006, 03:22 PM   #3
thanks MJK
forward, quoth garndmother in the snow.
Harri
P17 MTM TL help on MK's alignment tables led7 Multi-Way 7 18th May 2007 11:25 AM
Augspurger's alignment tables Dave Jones Multi-Way 22 14th April 2007 11:13 PM
please help with MJK's alignment tables just a guy Subwoofers 61 11th August 2006 07:40 PM
Transmission Line Alignment Tables MJK Multi-Way 8 19th October 2003 08:06 PM
