Internal speaker wire - diyAudio
Old 21st December 2002, 12:48 AM   #1
Default Internal speaker wire
:dunno
Hello,
I am 25% into my ProAc clone project and about to take on my first, dreaded crossover.
Please tell me..........
What is the best internal wire (i.e. guage, solid or braided, twist etc.) to use between:
a. terminal inputs to the crossover?
b. within the crossover itself?
c. crossover to woofer?
d. crossover to tweeter?
Any other tips?
Are there any particular screws made for mdf or is it a non-issue?
Thanks in advance!
Old 21st December 2002, 01:13 AM   #2
seangoesbonk's Avatar
Firstly, MDF screws... Yes! Unless you are the luckiest bastard in the world, using normal wood screws will end you up with a lot of "split" (delaminated?) MDF. You should always you a screw that has a non-tapered shank and big threads. (take a look at a deck screw)
As for speaker wire, (and I am not an expert)
This wire should be a least as good as the wire you will run from your amp to your speaker. (makes sense?)
You should try to solder the leads of the components together instead of connecting wires between them.
c. crossover to woofer? and d. crossover to tweeter?
I think it's safe to say that if you use the same wire as you used to connect the terminal to the XO, you should be okay. (I know someone will disagree...)
I used these screws for MDF and they worked great:
My girlfriend's sub is bigger than mine...
Old 21st December 2002, 07:11 PM   #3
diyAudio Moderator Emeritus
roddyama's Avatar
Steely,
I donít know if you want to take advice from a guy who has a smaller sub then his girlfriend. (kidding)
Seriously, there are only a few notes I would add to Seanís list.
Pre-drill your screw holes.
I will always use at least 5-way binding posts for speaker input connectors (gold over brass or copper)
Within the crossover, you can take the component leads to a common solder terminal, and I always wire-tie (tie-wrap) the components to a board.
The majority of the esoteric properties of speaker cable are given on a ďper-lengthĒ basis. For that reason, I will usually try to stick with a material property only for the crossover wiring. For example, if I ran 12ga silver Lutz wire from the amp (which I donít), I would use, maybe a 16ga silver stranded for the xover hook-up. I do use old (80ís vintage) Mogami 12ga co-ax OFHC copper wire for my mid-treble and up, so I also use 16ga OHFC copper for my xover hook-up.
Rodd Yamashita
Old 21st December 2002, 07:52 PM   #4
ARRRRGHHHHHHHH!!!!!!!!! I remember the good old days when 12" was enough...
Never, ever, ever even LOOK at MDF without pre-drilling!!! (especially on "end-grain" butt joints) I can't believe I forgot to mention it...
Old 22nd December 2002, 03:50 AM   #5
frugal-phile(tm)
planet10's Avatar
I have, of late, been using Plenum grade Cat-5 ethernet wire for internal wiring.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd December 2002, 03:58 AM   #6
roddyama's Avatar
dave
Dave,
Plenum grade Cat-5? Isnít this multi-twisted pair cable? How do you split the pairs or do you?
Rodd Yamashita
Old 22nd December 2002, 04:16 AM   #7
frugal-phile(tm)
planet10's Avatar
4 pr twisted runs per cable. I will either connect a pr of wires for each +/- or split a twisted pr and run a single wire for each +/- depending on how efficient the speakers are. For subs i'll run more (one cable with the strips for - and the colors for + is the lazy man method).
Some will strip the outher cover and twist together many-many prs.
It is an excellent source for cheap, very high purity solid core copper wire with teflon insulation.
I also use it for amp wiring when i can't be bothered with the 30 g stuff.
dave
Old 22nd December 2002, 05:08 AM   #8
roddyama's Avatar
Thanks Dave.
I went surfing and this is something I found.
http://www.duxcw.com/faq/network/audio.htm
Interesting. I must absorb for a while.
Rodd Yamashita
Old 22nd December 2002, 07:47 AM   #9
frugal-phile(tm)
planet10's Avatar
Looks like a good starting off point. There are quite a few DIY sites with Cat5 stuff including Gomer Cable and a little study a friend did on it.
dave
Internal arm wire problems Aleksunder Analogue Source 8 28th April 2009 02:17 PM
Internal Speaker Wire Toxdoc Multi-Way 1 27th December 2007 10:59 AM
Internal speaker wire. What do you use? gnugear Full Range 16 28th October 2007 11:46 PM
Quality internal speaker wire needed harrisni Multi-Way 12 28th August 2006 02:48 AM
Wanted internal speaker wire mgreene Swap Meet 1 9th December 2003 03:14 PM
Copyright ©1999-2017 diyAudio
